  1. Hi Gang
    I use DVDFab, Shrink, and DVDdecrypter. I lost a bunch of stuff on my computer, when I reinstalled all my things I mentioned above. They all seem to work except for one thing. When I finish with Shrink backup, it use to jump right intop DVDdecrypter, and burn it, now it don't. I have tried several things to change this but to no avail. It use to be the simplist way to do it and it did work great, with the least time and effort. I will at some time probably use Nero but for the time being I sure would like to know what I am doing wrong now with what I have.
    Any help appreciated>>>>>>>>>>Gunny
    USA
    It may have to do with the order in which Decrypter and and Shrink were installed. I use IMGBurn now. It works just like Decrypter for automatic burns with Shrink, but it's kept updated for the newer burners. How to set it up: http://forum.digital-digest.com/showthread.php?t=63874
  3. Hi Red
    I went ahead and downloaded imgburn, and I opened up Shrink and looked at the preferences, and it still does not give me the choice of setting imgburn as the burning setup. It still has Nero as the choice. I am sure I have the latest version of Shrink. Is there some thing as to the order that you download them.? If so what order should I download them.?
    Thanks..................Gunny
  4. Mod Neophyte redwudz's Avatar
    USA
    You need to install the modified version of Shrink from that site for IMGBurn to work. Just read through the link. It explains it all.
    I'm not sure if it's the order of install of Shrink and Decrypter that is your problem, but I believe Decrypter needs to be installed first for Shrink to find it. Uninstall Shrink, then reinstall it if you already have Decrypter installed. Probably a good idea to reboot in between.
