Results 1 to 13 of 13
This doesn't seem to have anything to do with authoring. Moving you.
When I click on the blank image, it says "User Account Exceeded Bandwidth", which is probably why we don't see the image.
i have.. theres on in there and these have worked b4 so how do i fix i have tried re installing and stuff and it just sits there
I've never burned bin images(vcd/svcd) to dvd, only cd. Maybe that's your problem and I don't think you can burn as is to dvd, cuz it's an image of a cd.Originally Posted by Evan7
yea but its not even working for anything else so thats no the problem, and i ahve bruend them 2 dvd's before anyways~
Evan~ -
What size is the image? What kind of image is it? VCD? SVCD? You may have to extract the mpegs and author to DVD seperately. Have you tried sticking a CD in the drive instead of a DVD?
Whether a CD will play or not depends on the DVD player. Some, but not all should be able to play a compliant SVCD, most should play a compliant VCD. Either one has to be to their respective specifications. BIN/CUE images will burn exactly as the CUE says. If it's screwed up, you will get garbage. You might try another BIN/CUE burning program beside Alcohol. It sounds like you have a corrupted video file or a corrupted program. DVD Decrypter can burn ISO and IMGBurn should also be able to do this.
Research finds many women need alcohol to enjoy sex
By zzyzzx in forum Off topicReplies: 0Last Post: 2nd Oct 2009, 15:52 -
Variable frame rate (vfr) and 120 (119.88) fps video playback big problem
By lovyagin in forum Software PlayingReplies: 0Last Post: 22nd May 2009, 05:40 -
Alcohol 120%
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2009, 13:59 -
Alcohol 120% files into a DVD5
By P T Wheatstraw in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2009, 23:16 -
Problem with Alcohol 120 mounting images on system start
By Talayero in forum ComputerReplies: 1Last Post: 29th May 2008, 12:53
