hi all
i have a series of 30 sec to 2 min avi dv files which i'd like to render viewable on my website
what formats would people suggest I convert them to and which software would do the job.
im looking to appeal to the biggest audience possible!
thanks!
Flash! convert with riva flv encoder or super or use the flash encoder included in flash.
Google video, youtube and several others use flash video. -
thank you!
isn't something like windows media a safer bet in respect of coverage? -
If everyone who visits your site uses the latest version of Windows, perhaps.
It's been said on these forums that the absolute most compatible format across all systems is perhaps MPEG-1. Windows Media isn't supported as well on other operating systems, such as Macs and Linux, especially if the WM video/audio/stream contains DRM. Older versions of Windows may need to have Windows Media support installed before they can use or view it - and even then, support for the newest forms of Windows Media may be limited or nonexistent on those systems.
Support for other formats, such as Real and FLV may exist on other OSs, but still be problematic. (The Mac has support for both RealVideo and FLV (the latter, to some extent), but I don't know about Linux.)If cameras add ten pounds, why would people want to eat them? -
i like wmv meself via windows moviemaker (comes with xp) or windows free encoder
320x240 is a good size for the web...but not the only of course
your biggest audience will probably be with a smaller file size
I use around 450kbps including audio but it will depend on your source quality
what conversion programs do most web sites use
By Magpye in forum Video ConversionReplies: 6Last Post: 24th Aug 2011, 10:53 -
wmv to flv - 3 possible conversion with ffmpeg- difficult choice
By bmb in forum Video ConversionReplies: 0Last Post: 1st Oct 2007, 15:00 -
codec downloads
By Noek in forum Newbie / General discussionsReplies: 2Last Post: 19th Aug 2007, 12:26 -
hauppuage 720x480 best conversion for web
By jwfc in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2007, 21:37
