Hi All
i need help i have a video i wanna delete that text froma a Video !!! so guide me how can i delete this!!
Here Video Link :
http://www.sendspace.com/file/anawij
Here Screenshots:
http://i7.tinypic.com/214eb7c.jpg
i wanna remove that Dctorrent from a video !!! plz help1!!
Results 1 to 16 of 16
It cannot be done. Even the best use of delogo tends to leave behind this watery-looking blob on screen.
Just get better source, or learn to live with the logo.
This is one reason I refuse to teach people how to add logos onto video. They go and do stupid crap like the problem you face.Want my help? Ask here! (not via PM!)
and I have added a text to my Video the size of the Video be4 text added was 137 MB and after i added the text it was 7 Gb why is that so isnt it possible to have size with adding text in Video normal size that i had be4 137 Mb ?
Did you save it in a different format?
Hunting, sure i'll go hunting. When is cow season? -
Most likely, Deepak didn't tell VirtualDub which audio and video codecs to use, and it saved everything in uncompressed form.
If cameras add ten pounds, why would people want to eat them? -
well i have hust added test in video and then i click on File then Save as AVi !!! the file format ws AVI !! did i smt wrong?Originally Posted by Ai Haibara
Take an extra 20 seconds and read your post. I have no idea what your trying to say. BTW, AVI means nothingOriginally Posted by DeepakHunting, sure i'll go hunting. When is cow season?
Select full processing mode and select a compression type before you save avi or it will be uncompressed.
"Art is making something out of nothing and selling it." - Frank Zappa -
In VirtualDub, before saving, you should make sure which audio and video codecs VirtualDub will use to compress your video. Otherwise, it may default to saving both audio and video without compression. You can check which codec is being used for your output video by selecting "Compression..." under the "Video" and "Audio" menus in VirtualDub.Originally Posted by Deepak
VirtualDubMod and other VirtualDub variants may handle it differently, as I recall, but I don't have any of them available at the moment, so I can't check.If cameras add ten pounds, why would people want to eat them? -
i have selected this Compression Option in Video i have also selected Codec but in option Audio i cant click on Compression any ideA?Originally Posted by Ai Haibara
SPAM can remove logotypes without fail. I don't know exactly how neatly the produced video will be, but you can give it a try.
How Do I Put Watermark/Logo on Video?
By iqbal88 in forum EditingReplies: 7Last Post: 11th Mar 2012, 19:17 -
Adding watermark to video
By Shaorin in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2010, 10:08 -
Add Watermark To Video?
By johngomez0468 in forum SubtitleReplies: 5Last Post: 29th Jan 2008, 17:48 -
Help remove watermark from video
By Syro_Str0m in forum RestorationReplies: 1Last Post: 14th Dec 2007, 09:46 -
adding logo/watermark using tmpgenc
By Bytez in forum Newbie / General discussionsReplies: 2Last Post: 24th Aug 2007, 16:25
