  1. I once knew of a programm that could analyze video streams and grade them based on encoding quality,but i don't remember how it was called.Can someone plz help me with that?I have made some test encodings,and i want it to analyze them and tell me which one is best.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You can achieve the same thing by watching all of the streams.
    Google is your Friend
  3. Gspot gives a quality value (Qf) as bits/pixel. But that's far from a real measure of quality.
    MSU has a video quality tool but I believe it compares the output to the source:
    http://www.compression.ru/video/quality_measure/video_measurement_tool_en.html
    May 2001
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  5. Ok i'll try the msu one,but instead of comparing the two encodings,i'll compare each one with the original,and try to draw conclusions.
  6. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Software will only tell you the obvious. The higher bit rate for any given resolution, will get the "highest" score, and hence be the "best".
    The real question, is what is the video far? What are your guidelines or limitations? What is your source? What is the destination?
    Regardless of what any software tells you, the best tool is your eyes. You are the one that will decide what is acceptable to you.
  7. Originally Posted by Krispy Kritter
    For example, you could encode with Xvid with a constant quantizer but two different motion search precisions. The file with the lower motion search precision will be larger. Software like GSpot will tell you the larger file has a higher quality (more bits per pixel) when in fact the two files are visually (nearly) identical.
