.i have been using svcd2dvd for a while,and apart from some tiny issues i havent had any more probs.
but ive tried using it today,and keep gettin the same error message?,can anyone please help.
copy of error
Version: SVCD2DVD 2.1
Build: 2.1.2308.33338
Type: System.NullReferenceException
Source: System
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at Microsoft.Win32.NativeMethods.CreateProcess(String lpApplicationName, StringBuilder lpCommandLine, SecurityAttributes lpProcessAttributes, SecurityAttributes lpThreadAttributes, Boolean bInheritHandles, Int32 dwCreationFlags, IntPtr lpEnvironment, String lpCurrentDirectory, CreateProcessStartupInfo lpStartupInfo, CreateProcessProcessInformation lpProcessInformation)
at System.Diagnostics.Process.StartWithCreateProcess( ProcessStartInfo startInfo)
at System.Diagnostics.Process.Start()
at x3284ccece41ee22b.xc5b4b7804027a156.x160a0bf4de8f6 bd0(String xd168ac2ed64c4662, String xa6a477a49a1a2599, String x450f47a9028f884b, xa0efedb9fec1e88f x8b49c96cd0348808, Boolean x74effd3a0f44569e)
at x3284ccece41ee22b.xd3764d4f1e921081.xe4bc971fa5b66 f8c(xece14591aa1abb99 x50afe96f7df19242, String x450f47a9028f884b)
at x3284ccece41ee22b.xd3764d4f1e921081.xc1a98f3d5c68f df5(xece14591aa1abb99 x50afe96f7df19242)
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
thanks guys for any and all help,im up creek without a paddle![]()
Results 1 to 12 of 12
At what point does this happen? Have you go a log of a run where this happens? (logs are in the logs folder)
hi chrissyboy.
the problem happens almost straight away when i click to make dvd.
set everything up as normal,assets/menus/background etc.
then acept menu,and click make dvd.
after about 3-5 seconds i get the error message.
ps do you want me to copy n paste the complete log file,or a certain part of it?.
thanks chrissyboy for your help.
just attach it please.
yep. Thanks.
Can you try copying The.Land.Before.Time_IX__Journey.to.Big.Water.avi to test.avi and just try that file on its own? This way i can see if it is the file or because the file path is huge...SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
.chrissyboy,ive tried each of the 3 files individualy without menus etc,and each starts to convert fine(ive left each until about 5-10%).
this is the last of 3 sets im trying to do.
the others had 4 files each,and turned out fine with no probs.
this one is the smallest of the set,i.e only 3 files so cant understand why the error?. -
did you rename the files before you tesed individually?
no mate,just left them excactly as they were and added as asset like i would if id of tried to put 2 or 3 files in,i.e when i started gettin the error.
cant work it out,because as i said ive done the other 2 sets with 4 files in each no problem.
all are same format,and all from the same source. -
Not sure what the issue is. Can you try a fresh project (as i noticed the other one was saved)?
ive just tried another project from scratch,out of curiosity.
still the same?.
ive even uninstalled svcd2dvd and reinstalled it,and still the same?.
i am curious what is meant by 'Message: Object reference not set to an instance of an object'?
do you know what it means chrissyboy?,ive never seen it before(but then again i havent seen any error message before either).
once again,thanks for your replies and your patience tryin to help me.
chrissyboy,ive just tried 1 of the previously saved sets that i have converted and burned sucessfully before i got this error.
now im gettin the same error with that set as well?,so i would rule out the films being at fault because ive already done set 1 and 2 before with no probs.
dont know if this bit of info helps?.
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 14:44 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Error reports in SVCD2DVD
By deoldeprinter in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th Nov 2007, 22:03 -
svcd2dvd error urgent request
By dvds2u in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 10th May 2007, 10:22
.i have been using
