DVD-Lab Pro 2.0 has been released![]()
I believe the new features make this one of the most advanced SD DVD Authoring packages for the PC (and at an extremely reasonable price)
Here are some of the new features:
- More compatible slideshow - in full GOP instead of I-frame
- Mega-Project with disk caching - this will cache data during designing into disk which will allow user to create project with huge amount of menus without windows crying for memory. With Mega-Project you can now create up to 640 menus per VTS!
- Each menu can have up to 30 cells inside where each cell can have its own set of buttons and other parameters.
- Smart Compile will recompile only the changed menu parts and keep the video vobs from previous compile. This way you can recompile menu changes within a minute!
- Multi-PGC title. The Segment Title has been now redone to a full Multi-PGC title. (Each segment in a Multi-PGC Title can now have its own pre and post commands)
- Audio Title can show new slide on each mark
- Pre and Post verificaton log
- Multiple Angles
- Buttons on Movies (Each chapter can have different buttons)
- Faster transition encoding
- native 24p support (Note: this is not 23.97 with pulldown)
- Simpler to use and more robust audio transcoder - can transcode any audo file for which you have codec
- Subviews in Conections - place certain project objects to a freely definable subview (up to 9 subviews) so you can work with them separate from the main “Global” connection view.
- VM Commands can be now placed not only before but also after the Dynamically generated commands
- Multiple selection in Connections
- Perspective Transformation of texts and other objects
- Package object in Menus
- Show VM commands in Connections
- Pause on chapters or at the end of movie (Continue by pressing Play button)
Regards,
George
Now this looks interesting! Does the audio preview still work the same? Do you need to open the Pro Tools to preview audio? thanks...
As in version 1.62, the audio preview is for muxed streams only (i.e. not elementary streams). You are correct, ProEx can preview the audio for elementary streams.
Regards,
George
help with DVD Lab Pro
By medo_256 in forum Newbie / General discussionsReplies: 1Last Post: 22nd May 2010, 21:02 -
Help with DVD Lab Pro
By blacksheepdownunder in forum Authoring (DVD)Replies: 12Last Post: 31st Dec 2009, 23:01 -
DVD-LAB Pro 2
By Sanmaame in forum Video ConversionReplies: 4Last Post: 23rd Oct 2008, 04:42 -
DVD Lab Pro
By Flying Doctor in forum Authoring (DVD)Replies: 6Last Post: 16th Jun 2008, 09:00 -
DVD Lab Pro 2 help
By jonghyunchung in forum SubtitleReplies: 1Last Post: 17th Jan 2008, 07:53
