In Vegas, Is it possible to have negative effects during playback by checking the "reduce interlace flicker" button when you don't need to check it?
IMHO, I don't think so.
Anyway, I guess checking Reduce Interlace Flicker in Vegas won't help as much either (as Video Supersampling).
If you have some trouble with very sharp video (or specially pics), you can use one of these 2 plug-ins: Gaussian Blur (I don't like this one in Vegas) or Light Blur (levels art 0,0400 up to 0,0700). If you are planning to render a slide show (showing pics + animating a virtual camera with keyframes), you can use Photoshop to add some blur (Gaussian Blur Filter at 0,4 to 0,eight) depending on the sharpness of your pictures. It's a good idea to render and preview the resut on a TV monitor. If you still have some "noise" on the video, take note where they appear and insert some more blur (you have to blur more than those figures shown above). Water (surface of the sea, of a lake) would be a classic exemple.
XviD4PSP Brightness/Contrast setting to reduce PSP "Ghosting"?
By stephens in forum Video ConversionReplies: 0Last Post: 13th Sep 2009, 12:42 -
I can't reduce the size of a file using AutGK - "no fps"
By HartsVideo in forum EditingReplies: 38Last Post: 3rd Jan 2009, 23:02 -
Flicker, scanlines and non "anti-aliased" image
By F u r u y á in forum Authoring (DVD)Replies: 2Last Post: 19th Jan 2008, 02:35 -
A must read "sex" story! Guarantee it will reduce your stress!
By moviebuff2 in forum Off topicReplies: 2Last Post: 18th Jan 2008, 15:51 -
Does DVD "checking" software really work
By jbartosh in forum MediaReplies: 27Last Post: 16th Nov 2007, 20:45
