I used TMEMPC to mulitiplex a two MPG1 files. I did this becasue after reading the instructions for dvdAuthorGui. I realized that I needed "elementary streams". I ended up with four files. Two mp2 files and two m1v files. I then started DVDAuthorGui and addes those file into the interface. I pressed Author DVD without adding any titles or chapters and I got this error
"DVDAuthorGUI 1.008b - 1/14/2006
Send problems with DVDAuthorGUI to liquid_217@hotmail.com
***please wait while the titles are multiplexed.
*multiplexing title: 1.....
INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
**ERROR: [???] Unable to open file C:\Documents and Settings\xxxxx\Desktop\Clips\BAWZ\B-WZ_BT69.m1v for reading.
*multiplexing title: 2.....
**ERROR: [???] Unable to open file C:\Documents and Settings\xxxxx\Desktop\Clips\BAWZ\B-WZ_JWA2.m1v for reading.
*authoring title(s).....
Process aborted due to above error
There was an unknown error. Please review the log for more information.
Windows Media player will play these files fine. Should I use some other tool to make the streams.
without knowing any more details, I am afraid i can't help you. It seems something is wrong with the m1v file. try using batch demux (on dvdauthorgui's download page) to demux and see if that works for you.
DVDAuthorGUI Problem...
By beckmen in forum Authoring (DVD)Replies: 12Last Post: 1st Jul 2010, 12:34 -
DVDAuthorGui run-time error 75
By boborg in forum Authoring (DVD)Replies: 4Last Post: 16th Jan 2009, 14:37 -
DVDAuthorGUI: How do I write?
By videohalp in forum Authoring (DVD)Replies: 1Last Post: 8th Jul 2008, 20:29 -
DVDauthorGUI question
By AlecWest in forum Authoring (DVD)Replies: 2Last Post: 20th May 2008, 12:46 -
DVDAuthorGUI Unknown error - log included *SOLVED*
By ChibiTomo in forum Authoring (DVD)Replies: 2Last Post: 9th Oct 2007, 13:18
