I have two video files, encoded separately, and want to join (combine) them in one DVD (original file is 700mb, xvid, 50 min each...so I think they will be fit in one dvd). I want to use dvd-lab pro for authoring. Please let me know how to add two video/audio files (m2v/mpv, AC3/MP2) into the program. They are two conseutive episodes (#1 and #2). I want to combine them with no break/pause in between.
there are quite a few guides: https://www.videohelp.com/dvdbackup
Google is your Friend -
Sorry for the confusion. I mean by adding two video/audio files are not two DVDs (Video TS/Audio TS), but just two encoded video/audio files before authoring.
Hi kthan,
You will need to use the add movie for each of them and the from the connection screen connect the end of the first one to beginning of the second one.
Now editing the movie, like you mention:
I don’t know if the breaks are commercial or not, if they are commercial you will need a movie software editor, like Sony Vegas or Premier.I want to combine them with no break/pause in between.Some Day I will….. -
You can't do it in DVD Lab Pro. DLP does have an object called a movie segment, which will allow you to put both halves on the same timeline and play them back as one object, however the join will be the same as you would see at a layer break.
If you want seemless, join them before encoding so you have one movie to author.Read my blog here.
Aren't we talking about creating a playlist here? Or have I missed the tricky bit?
how can I use .SUP files with DVD Lab Pro
By taasan in forum SubtitleReplies: 23Last Post: 7th Jan 2013, 08:09 -
Can u use PSD files for menus in DVD LAB PRO?
By Cygnus111 in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2010, 16:02 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56 -
Add a menu to a DVD without re-authoring, using DVD-Lab Pro
By petar in forum User guidesReplies: 38Last Post: 12th Mar 2008, 13:22 -
DVD Lab, Is it possible to add video to background on the menu
By frozenwind in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2007, 11:09
