I have a music mapp on 14 Gb. and i want to burn the whole mapp with nero
splittet on 3 DVD disks. and i guess thei will be part discs that require eatch other? if that is possible with Nero 6?
i consulted the manuall. but its so damn big so i could not offcorse find any info how i create
a part disk..its oviosly not a regular data disc i shall use anyway
so what burning type shall i use i ask..to save some time?
I thought there was a data backup option in Nero just for that purpose and it automagically split the data across multiple dvd's. You won't be able to use the data in dvd format, but it will be backed up.
Google is your Friend -
As far as I know Nero 6 has no splitting capability. I am not sure one of those splitter programs can work on something this big any way... Hmmm...
ok i see...is there any other-way to burn 14 Gb of Mp3 files somhowe and get the whole mapp in one,without having to fill upp 4.5 gb on eatch dvd manually you know..?
From the Nero webpage: For backup duties there is BackItUp. Although basic, it does allow disk-spanning compression and scheduling even if the interface is a little frustrating at times
It is part of the Nero Suite and appears to be included in version 6 and 7.Google is your Friend
Possible to convert ONLY audio part of WMV, but not the video part?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 27th Jun 2011, 19:57 -
Nero Disc Image?
By angryassdrummer in forum Video ConversionReplies: 2Last Post: 1st Jul 2010, 11:36 -
how can i edit a small part inside a movie and make that part look bigger?
By xxquatroxx in forum EditingReplies: 1Last Post: 24th May 2010, 16:32 -
TMPGEnc cannot open the video part of the file, only the audio part can.
By dzsoul in forum Authoring (DVD)Replies: 15Last Post: 3rd Apr 2009, 09:36 -
after buring DL+R disc, my burn can't burn -R disc, please help!
By princejoe18 in forum DVD & Blu-ray WritersReplies: 1Last Post: 5th Sep 2007, 08:44
