Hey guys, this is KingChuck.I'm pretty expierence with video editing and using Sony Vegas6, but I have a question. I just got a new camera, which records on miniDVD. When I put the footage onto my computer, it is in .mpg format. And, Sony Vegas can not open .mpeg video formats. I know there is some .mpeg plugin or something that you can get so I'm able to import these videos into Vegas so I can edit them, but I can't find it.
Any help would be appreciated, thanks much guys. 8)
HaloResort.net
-_- -
If you have correctly registered Vegas you should have all the plugins you need already working. You may have to consult the Sony support forums for a solution.
Your other option is to open the mpegs in virtualdubmpeg2 and save them as DV avi using the Panasonic DV codec.Read my blog here.
Importing an MPEG-4 to sony vegas platinum 9
By txpredator in forum Newbie / General discussionsReplies: 0Last Post: 24th Oct 2010, 19:25 -
Rendering MPEG 2 in SONY VEGAS PRO 9
By sfalcon in forum AudioReplies: 1Last Post: 21st Feb 2010, 16:07 -
Sony Vegas MPEG-2 encoder
By prl in forum Authoring (DVD)Replies: 1Last Post: 3rd Dec 2009, 05:46 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 11:00 -
mpeg TS files works with no sound on sony vegas what i do/??
By khalid81 in forum EditingReplies: 11Last Post: 20th Jul 2009, 10:20
