I am having a problem. I feed my DVDs into MacTheRipper, and they come out fine. But when I feed the VOD files into ffmpegx, it doesn't always work. Most of the time I have things popping out in Spanish! Is there a way to secure it so that I'm not bothered with this Spanish stuff?
ABF
When encoding with a VIDEO_TS folder as input, the desired audio track is selectable in the Audio tab. If tagged correctly, it should contain language information.
When encoding from a single vob file, the audio track is only identifiable with a number. To make sure you selected the right audio track before encoding, you can preview the settings with a selectable start time (in case the spoken language start a few minutes into the movie). Press Return or Esc to exit the mplayer preview.
Subtitle Translation Feature
By frmys in forum SubtitleReplies: 5Last Post: 23rd Feb 2011, 02:14 -
Overlaying sound with translation over a movie.
By Maserati_Shamal in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2010, 17:13 -
interpretation, I try to copy it because I enter the translation again
By krrish in forum Authoring (DVD)Replies: 3Last Post: 9th Sep 2008, 14:14 -
Recommended subtitle format for translation
By niko84 in forum SubtitleReplies: 11Last Post: 3rd Feb 2008, 18:35 -
Help with free AVI Trimmer GUI translation required
By DmitryV in forum Off topicReplies: 0Last Post: 19th Jul 2007, 03:49
