    May 2005
    canada
    so i found out recently that there are mainly two types of lcd monitors; 8bit and 6bit
    (although good luck trying to find out what a particular unit is)
    here is an interesting article about it:
    http://compreviews.about.com/od/multimedia/a/LCDColor.htm
  2. are you looking to buy one?or just posting info?
    May 2005
    canada
    both
    Jul 2006
    Budget? Size?
  5. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    If you are a gamer looking for speed, you will see no real difference at 6bit. Games can't afford the luxury of 24bit color.
    If you are doing home theater, there are other more important issues such as contrast, gamma and ability to refresh 60-100Hz.
    http://www.kiva.org/about
  6. Originally Posted by edDV
    What are you saying? Games have better resolution and colors than any broadcast HDTV... There are on real 24 bit and resolutions can be higher than 1900x1080.
    Anyway:
    http://www.behardware.com/articles/606-4/test-the-influence-of-electronic-components-o...cd-colors.html
  7. Member edDV's Avatar
    Mar 2004
    Anyway:
    What games do that? I'll admit I've been ignoring games for a year.Games typically will use a lookup table (LUT) to pick a few from the milions of possible colors. Tell me a commercial game rendered to DVD at 1920x1080 let alone higher? That game would be very slow.
    XBox has loose requirements for 720p but most upscale to get to 720p or 1080i. Instruct me.
    I doubt there is a gamer anywhere that cares if the monster is a particular Pantone shade of green. Only ad agency geeks seem to have those kinds of color sensitivities for packaging or food color match.
    http://www.pantone.com/products/products.asp?idArticle=114&idArea=16
    I like Pantone's observation "WHY WYS IS NOT WYG"
    Gamers seem to care about 1) speed, then 2) speed, then 3) speed then # colors on screen at one time. Never have I heard an argument over accuracy of color shades.
  8. There are gamers and gamers. There are videocards and videocards. PC can go beyond any gaming console resolution. The latest one:
    ...four GeForce 7800 GTX chips, Nvidia's current highest-end silicon. With that much power, Nvidia claims that you can achieve 2,560x1,600 resolution output, which is well higher than the 1,600x1,200 capability we're used to considering as the high end of 3D display. Nvidia also brags about 32X antialiasing and 16X anisotropic filtering, twice the current capability of standard SLI configurations. Of course, to take full advantage of Quad SLI capability, you'll need a display capable of such high resolution output, and for that, you'll need to drop more than $2,000 on a 30-inch LCD, in addition to the price of each card.
    From: http://www.cnet.com/4831-11405_1-6412837.html
    I admit thou that on my PC I run games at only 1152x864 and no antialiasing, because of my 19" screen and limited disposable income in that direction
