I have a .mdk video file and i converted it with River Past to .avi (xvid) but now it doesn't have the subtitles.
I tried ripping the subtitle from the original .mdk file but, virtual dub doesn't do any neither does any program that i've found.
Any help?
Results 1 to 14 of 14
Do you mean .mkv? I've never heard of an .mdk video file. The River Past Video Cleaner page in VideoHelp's Tools section also doesn't mention an .mdk format, as far as I saw.
I did notice this in the changelog, though:
6.8 11/17/2005
* [New] (Video Cleaner Pro) Overlay subtitles if VobSub is installed.If cameras add ten pounds, why would people want to eat them? -
Originally Posted by Baldrick
Another thing,
The video doesn't work on my philips dvd player. So I converted it into the different formats, and it still freezes at like at 00:05, i press the menu thing, exit menu, now it's frozen at another time.
Any help? The video doesnt work on the dvd player. -
Which Philips player are you using? The 642, which I have, is a bit picky about the AVI formats you can use with it; I'm not sure about the newer Philips players. Run the problem AVI in question through GSpot (preferably the 2.5 beta, not the 2.1.x or 2.2x versions) or a similar utility (MediaInfo (if I remember correctly), AVI2Clipboard, etc.) and post screenshots of the resulting information (or in AVI2Clipboard's case, just paste the information into a post). Erase the information about the filename and file path, if you prefer. That way, we'll be able to see if the AVI has something that your player doesn't like.
Originally Posted by Ai Haibara
This is the picture of the converted one, on Gspot:
This is the picture of the original MKV file, on MediaInfo:
Install the GSpot 2.52 beta. It'll show more information about the file than 2.21.
One thing that I can see about the AVI that might cause problems is that the video appears to use uncompressed PCM audio. I'm not sure, but I think most stand-alone DVD players only allow for MP3 audio streams in a DivX/XVid file (if the player can play them, of course ).
Recompress the audio using VirtualDub, or something similar. (Set Compression under the Video menu to "Direct Stream Copy" so that it doesn't recompress the video.)If cameras add ten pounds, why would people want to eat them? -
Actually the subtitles are not messed up. I just can't see the next sentence in the subtitles (the lower part of the video).
I probably can on my bigscreen tv, as it usually shows the subtitles with only a bit cut off that's not even annoying.
But i'm viewing the video on my 27' inch tv, any help? -
The problem you're experiencing is called 'overscan.' All TVs (excluding hi-def TVs, I think) have this 'problem' to some extent (it's actually an intentional design), varying from TV to TV.
I don't know if there's a solution that will work directly with alltoavi. Search the forums for the word 'overscan', and you'll see the suggested methods of creating DVD video to compensate for overscan. Most common is reencoding the video with a black border on all four sides, so that the actual picture fits more into the 'safe zone' (advanced authoring programs will refer to that area using terms like that).If cameras add ten pounds, why would people want to eat them?
What is a Reasonable Size for a DVD File Converted to AVI or MP4?
By Novice20 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 22:58 -
Audio/video Out of Synch in Converted AVI File
By Novice20 in forum Video ConversionReplies: 1Last Post: 31st Aug 2011, 03:10 -
No video only sound in the beginning of the converted file from AVI to DVD
By lankafta in forum ffmpegX general discussionReplies: 1Last Post: 21st Jul 2009, 23:16 -
How to fix the lagging audio of a converted AVI file?
By PunkMaister in forum Video ConversionReplies: 15Last Post: 17th Feb 2009, 19:38 -
Seeking opinions about my converted dv-avi file
By hygieneboy in forum Video ConversionReplies: 35Last Post: 28th Jan 2009, 18:26
