  1. Can someone take a look at this site and tell me what may be wrong with it?
    http://users.adelphia.net/~gideond
    http://users.adelphia.net/~gideond/html/menuframe.html
    The second is the actual problem page. There should be an image showing below the Site Info button that links to www.animecornerstore.com
    It shows up fine in IE but not in Firefox, yet it is coded the same as the other buttons. Any input one what is causing this is appreciated.
  2. Member Prot's Avatar
    Dec 2003
    Oregon
    Shows up ok for me in Firefox.
    I saw nothing out of the ordinary in the html that would cause the problem.
    Was nothing showing up, or did you get a small red x?
    TANSTAAFL
  3. I finally figured it out. It's adblock causing the issue. Evidently since I have it in a folder call "ads" on the server adblock automatically put it on the block list. I changed the folder name to "aff" for affiliates and it shows fine now. I didn't think to check that since the other images loaded just fine.
