I am using Nero 7 Ultra Edition.
I am trying to write a data dvd using nero express but when adding files to be burned it refuses to add zip files.
I have checked all the setup preferences and found nothing to exclude these files. In the add files window the add all files is selected.
Anyone else having this problem?
You do have it set to DVD and are burning as data, correct?
What is the error message you are getting?TANSTAAFL -
To Prot
Thanks for the reply.
Yes it is set for DVD data.
There is no error message.
All files will be added except zip. I added enough files to fill up a dvd and then found out that I was short on files. Turned out to be 12 zip files that did not add.
I experimented with just zip and got nothing. -
I'm not familiar enough with Nero to give you an answer, but a zip file is a data file, so it should burn.
I found this on Nero's site, however.
http://www.nero.com/nero7/eng/Nero_Burning_ROM_Release_Notes.php
Apparently Nerto does a virus scan on data files, but was unable to do this on zip files in previous versions.
Try updating your version of Nero.
Remember: Google is your friend. You can do these type of searches on your own.TANSTAAFL -
Are you trying to feed NERO a file greater than 1GB in size?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
TANSTAAFL - There Ain't No Such Thing As A Free Lunch
from "The Moon is a Harsh Mistress" by Robert HeinlinTANSTAAFL -
Right on.[/quote]
downloaded SVCD2DVDv2.5.zip won't open
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 6th Aug 2011, 16:48 -
I'm having problems downloading ZIP files.....
By R.STEED in forum Newbie / General discussionsReplies: 8Last Post: 30th Apr 2009, 12:16 -
Some Avi files will burn on dvd, others won't??????
By Qvezzy in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 11:47 -
Nero won't burn video DVD
By solo_voyager in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2007, 22:06 -
Why do Zip/RAR files have a habit of corrupting?
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 21st Sep 2007, 02:40
