I burned a movie using nero latest version. When I play it on my DVD player I can not search for any part of the movie I can use the FF and REW but not move to a part in the movie. When I display the time the time remaining is always zero. Is this the reason that it can't search it does not know how long the movie is. And do you think it is a nero problem.
Derek
Results 1 to 13 of 13
For me, this issue was Nero...If I made an SVCD image using VCDeasy w/o PBC control...I was able to FF/RW properly...I here the latest version of Nero does not have htis problem though.
<font size=-1>[ This Message was edited by: Kdiddy on 2002-01-09 10:36:51 ]</font> -
I am using latest version of nero. you used vcdeasy could you search for a part of the film ie move to say 20min.
Derek -
with PBC control OFF, no I cant, if I turn it back on, I can jump to a specific point in time, but I lose the ability to FF/RW, it may be a specific prob with my player...I have hacked the firmware on itt o do other functions as well.
Thanks kdiddy I used VCDeasy and I was able to use the search funstion on mt DVD player. I now know it is a nero problem thanks again
Derek -
Now that I know it is a nero problem is there anything I can do so that the search function works on my DVD player using nero.
Derek -
I have VCD created by NERO and my DVD player shows "PBC Play" all the time. I think problem is Lot_x.vcd and Psd_x.vcd in the \ext folder. I have some VCD without those files and they work fine. I don't know how to change the template in the NERO.
No.
Nero just creates a dummy PBC system on all its VCDs. This is not an issue -- most/all VCD authoring proggies do this by default.
You can acutally set VCDImager to create a VCD without PBC if you so wish but this should only be relevant for a simple multitrack disc as you cannot have menus, chapters, etc., without PBC: http://www.geocities.com/medinotes/vcd/simple_multitrack.html
Furthermore, you cannot use "time search" while PBC mode is on. A time search will implicitly turn off PBC.
Regards.
Michael Tam
w: Morsels of Evidence -
Vitualis, I use the time search on my Apex all the time and I don't remember it messing up the pbc of the disc.....maybe I will try it again and actually pay attention this time
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
When I say "time search" I mean that you punch a button on the remote and then enter the time on the disc/track (e.g., 30:00 for 30 min). This for every VCD/DVD player I've seen necessarily requires it to disable PBC.
FFW and RWD should not affect PBC in anyway.
Regards.
Michael Tam
Thats right when I search for a time on the svcd it does nothing it does not mater if pbc is on or off. I know it is something to do with latest version of nero as previous version worked ok. but if I use vcdeasy it cured the problem.
DVD player "STOP" function question
By efiste2 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Mar 2012, 16:27 -
Comment on Search Function
By smartel in forum FeedbackReplies: 4Last Post: 21st Jun 2011, 04:53 -
Which Media Players has File Search function via Remote Control
By suijaypao in forum Media Center PC / MediaCentersReplies: 0Last Post: 27th May 2010, 17:56 -
Is there a blueray player with audio delay function on the market?
By Patrice1981 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 21st Sep 2009, 09:15 -
Improve search function on forum
By cd090580 in forum FeedbackReplies: 0Last Post: 2nd Aug 2008, 09:59
