  1. I was wondering if there is an alternative program out there to load a VOB file and preview the IDs so I know what I can demux to M2V and AC3 (EG: Menus and Motion Menus with audio, Trailers, FBI warnings, etc...). I have been using VOBrator v0.2 beta but after reinstalling XP it doesn't seem to work right anymore. When I play a VOB ID it will freeze after I stop playing it. Then I have to close the program and lookup the file again, then go on to play the next one.... I've tried finding something similar to do the same job but can't find anything.
    The most useful thing about it is the possibility to open a VOB file, navigate through all IDs, preview them and select/deselect the IDs that I want demuxed...
    Can anyone recommend something for me ???
    Thanks in advance...
  2. Hi-
    I'm not entirely sure this is what you want, but VobBlanker opens complete DVDs from the IFO. You can then break it down and Preview whatever you want by PGC or Cell. You can use it to extract, but not demux. PGCDemux is better for demuxing by PGC, Vob ID, or Cell.
  3. PGCDemux would have been an excellent tool, if you could preview the ID/CELL/PGC and could select more than one source at a time for Demuxing...
    Hope the developer listen to my prayers... ))
    Thanks...
