I downloaded a movie, and now I have an AUDIO_TS folder that contains the movie. Using Nero Showtime, I can play the movie from the folder, but it has no menus. If I want to reauthor and put menus in it and burn it to a DVD, is this "ripping"? If so, please point me to the correct tutorials.
Also, why is it an AUDIO_TS folder, and not a VIDEO_TS folder? Everything else I've ever downloaded ends up as a VIDEO_TS folder. Will this have a bearing on what I want to do?
Thanks to anyone that helps.
try tmpgenc dvd author, select add dvd video and choose the audio_ts folder and make your meeeenus.
it should be video_ts if it is a dvd-video. audio_ts is for so called dvd-audio discs but I think they can also contain video...
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 30th Mar 2012, 00:32 -
Automated video conversion with a "watch" folder(s)
By fender4645 in forum Video ConversionReplies: 1Last Post: 8th Apr 2010, 16:40 -
How to get an "l"not an "I" when ripping the dvd subtitle to text format
By cairuitao123 in forum SubtitleReplies: 12Last Post: 24th Mar 2010, 21:50 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 14:59 -
Make menu for "VIDEO_TS" folder (files inside it)...
By Chana1 in forum Authoring (DVD)Replies: 18Last Post: 24th Jul 2007, 09:29
