Been using svcd2dvd without any problems for about two years, until last friday. Went to run program as normal, but after it loaded, it wouldn`t respond. Re-booted pc, with no joy, so removed it and re-installed it but it still won`t respond. Even tried v2.0, but just getting same result neither 2.0 or 2.1 will respond. I`m buggered. Can anyone help?
Could be a .NET issue, try reinstalling .NET 1.1, then reinstall S2D.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Originally Posted by Jikchung
Are you getting any error messages? Does the program open at all? Give as many details as possible.
Dwight
- Herm Albright
did you install SP1 for .net 1.1 too?
it should be added that you may need to uninstall .net 1.1 (& sp1 for .net 1.1) to get a "clean" reinstallation...
Not Responding and what is the ! about?
By Wicked_T in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 10th Sep 2010, 16:44 -
New Computer w/ Vista- Programs Not Responding
By jkaufman in forum Video ConversionReplies: 4Last Post: 13th Dec 2008, 22:28 -
(not responding) problems
By pjcom in forum EditingReplies: 1Last Post: 9th Jul 2008, 11:36 -
HDD Not Responding Correctly
By RKelly in forum ComputerReplies: 7Last Post: 29th Jan 2008, 22:03 -
Toast Titanium not responding....then it does
By SonicMix in forum MacReplies: 5Last Post: 5th Sep 2007, 13:59
