    Jul 2006
    I have been trying to burn (copy backups) for my dvd's. Everytime, I start off with the encription program then go to the shrink program and finally the burner. I recevied no errors durning those processes. When I try to play the backup disc on my xbox 360 it can not read it. When I play it on my dvd player I get the following message on the screen:
    'THE DISC PLAYBACK FORMAT MAY BE DISABLE."
    What can I do to correct this problem?
    tried different dvd media? www.nomorecoasters.com
    do you see any files on the dvd using windows explorer?
    Jul 2006
    I didn't see any files on that movie pertaining to windows before I burned it to a disc.
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    What Baldrick meant was, if you insert the DVD into your PC's DVD drive, can you see any files while browsing the disc, using Explorer?
    Jul 2006
    When I use Explorer to look at the files on the PC. It shows two folders.
    One Audio folder which is empty and a Video folders contains 3.48 gigs.
    What does that tell you?
