I'm doubting cos the PAL camcorder is double prize than the NTSC camcorder but i live in region where the PAL is basic system.
I've read all the articles about this subject and understood this:
- the pal camcorder gives better picture quality that the ntsc one
- if i "capture" the ntsc source on the hdd and convert it to pal will lose the picture quality
Is it right?
Freethinkers Are Dangerous !
PAL on PAL is...in my opinion....better picture quality. NTSC on PAL looks pretty good. And of course we know that PAL on NTSC is damn near impossible AND it looks pretty crappy....again...in my opinion.
If you are in PAL-Land then consider yourself lucky....you(we) can play anything and it looks pretty damn good.
I'd stick with PAL. -
I would recommend a PAL camcorder if you are in a PAL region and NTSC in an NTSC region. This is to allow easy playback to local TV sets and recording equipment.
With DV format the quality differences are minor. The same data rates are used for PAL and NTSC. PAL has 20% more vertical lines (720x576 vs. 720x480) but NTSC has 20% higher frame rate (29.97 vs 25). The same issues carry over into interlaced DVD.
For HDV and HD both record the same frame sizes (e.g. 960x1080, 1280x720, 1440x1080, 1920x1080) but NTSC records at higher frame rate. -
As a separate note, I think that a PAL/SECAM/NTSC TV set is not a problem in Bulgaria (if is, buy one from Romania
That TV set will let you watch the NTSC tapes or DVD's in their native format without any conversion - maximum quality.
PAL & NTSC in the same camcorder
By griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 11:55 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
ntsc tapes pass through pal camcorder into mac for ntsc playing?
By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 17:19 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45 -
Pal and NTSC Camcorder
By NightFire in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 20th May 2007, 20:01
