Hey all. I'm having trouble burning KVCD's to CD-R, I use nero 7 but when I try to use "burn image to disc" I get errors as soon as I hit the burn button...
images removed, all fixed
Why is this happening? I'm using standard philips 700mb/80 min CD-R's with burn speed set to the recommended 8x speed, the burner is fine as it will burn other types of cd (such as audio). If I don't use "StartSmart" and just double click the .cue file, nero opens but crashes after a second.
Results 1 to 12 of 12
I've tried various kvcd images avaliable on the net from different locations, so it's something to do with nero I suspect.
I'll search around now but do you know of any reliable freeware applications to burn image files? -
imgburn or DVD decrypter (imgburn is the burning engine from decrypter - same author)
Read my blog here.
Can you try burning at 4x? Sometimes slower speed burning can help. You might also want to get Daemon tools and mount your images before burning and try playing them. Do they play OK? How big are they? Any chance they are too big to fit on one CD-R?
bridgey6 - You need to be careful because admitting that you downloaded these images is most likely a violation of Forum rules. -
Originally Posted by bridgey6
Your problem is probably because it's just another botched illegal file. With as much as uploaders screw up video/files and make it detestable quality, it's a wonder that group like RIAA and MPAA even care. It's all messed-up trash. It might even be a fake file altogether.Want my help? Ask here! (not via PM!)
Who's trying to be clever? I'm simply stating the truth. You have no way of knowing whether I or anyone else here is downloading/burning legit content or not.
Turns out the problem was Nero as the very much legal video file of my family holiday, which was turned from a DVD to a KVCD by a friend over this new fangled high speed internet thing since I haven't got a clue how to do it so that I can make copies cheaply and easily to give to other friends, is now playing on the dvd player.
Once again thank you to those people that actually contributed. -
Originally Posted by Jeremiah58
VCDs and SVCDs, (and derivations of them such as what the KVCD template creates) are burnt in mode 2 which allows for approximately 800MBs on an 80 min cdr, so that's why they fit.
Here's a more detailed answer:
https://www.videohelp.com/faq#740
Mpeg Streamclip suddenly refuses to create DV's
By Gretchen in forum Video ConversionReplies: 3Last Post: 29th Oct 2011, 14:53 -
AVIsynth refuses to work anymore... Plz help!
By Nagashi in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2010, 17:44 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 16:11 -
trying to burn a KVCD using Nero SmartStart Essentials
By nudge in forum Newbie / General discussionsReplies: 5Last Post: 28th Jun 2007, 15:10
