I am capturing video from the TV using VS and a TV Tuner card. After I get the settings setup I click on the Capture Video icon. VS starts to capture the input source. About 15 to 20 seconds into the capturing I get the following message:
Unexpected error: Unexpected error: The sample start time is
after the sample end time.
After I click on OK button the capturing stops. I am unable to get anything going. Every time I click on capture video I get this same error message each and every time.
Nowhere is there any explanation about this message.
If you can't get the answer here, try uleads relatively new forums (if you can believe that) @ http://phpbb.ulead.com.tw/EN/index.php
Hi,
I'm having the same problem and wondering if you ever found a solution?
Thanks -
That was 6 years ago, but no, I never got an answer. I haven't been doing video capturing since then. I kind of got away from it but did a little bit now and then but if I remember correctly I didn't encounter that problem later on - maybe it had to do with me re-installing VS or something along the way happened and I don't recall seeing that error message again. That doesn't mean it would not have occured it's just that I never did a lot of capturing after that. Sorry I couldn't be of any help to you. If you ever find the solution I would however appreciate it if you would post back here because I do plan on returning back to do more of this stuff.
When I was doing it I think I outputed AVI and then loaded the AVI back into VS and converted the AVI to DVD format which for a two hour movie it took all night. I don't remember ever outputting to MPEG as that, I think, had to be converted to AVI before VS could process it for DVD but I am not sure now as it's been too long ago and I have forgotton much of what I used to do
Corel Video Studio Pro x4 jumps when capturing?
By TheKillerQueen in forum Capturing and VCRReplies: 3Last Post: 17th Apr 2011, 11:01 -
MP4 only shows half the video
By Dapuma in forum Newbie / General discussionsReplies: 2Last Post: 16th Apr 2010, 10:17 -
Capturing video through Vegas Movie Studio 9
By Michael Rodriguez in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2010, 17:33 -
PS3 shows no video?!?!??!?
By jyeh74 in forum Off topicReplies: 1Last Post: 2nd May 2009, 10:29 -
My video shows up pixels when playing
By triumph2004 in forum Newbie / General discussionsReplies: 3Last Post: 9th May 2007, 15:24
