    May 2005
    baltimore md
    I was just wondering if i can do something about when I convert a 2 mpeg movie to dvd at the split the sound goes about a second out of sync
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.1
    Version: 2.1.2308.33338
    Executable: E:\program files\svcd2dvd\SVCD2DVD.exe
    Executable size: 2.85 MB
    Executable size in bytes: 2998355
    Executable CreationTime: 4/27/2006 11:33:02 PM
    Executable LastWriteTime: 7/11/2006 11:19:53 PM
    Executable LastAccessTime: 7/23/2006 5:20:36 PM
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Professional
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 1
    Local: 0409
    Total Physical Memory: 1.99 GB
    Free Physical Memory: 1.54 GB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.95 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: NVIDIA
    Computer Model: AWRDACPI
    System Type: X86-based PC
    Computer Name: JASON
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 2
    User Name: JASON\Home
    ***************************** Processor ****************************
    Manufacturer: AuthenticAMD
    Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
    Description: x86 Family 15 Model 43 Stepping 1
    CPU Speed: 2.42GHz
    CPU FSB: 201MHz
    L2 Cache Size: 512 bytes
    CPU Speed: 2.42GHz
    CPU FSB: 201MHz
    13:21:11: Logical CPUs: 2
    ***************************** Time Zone ****************************
    Time Zone: (GMT-05:00) Eastern Time (US & Canada)
    ****************************** VIDEO *******************************
    Processor: Radeon X1800 Series (0x7109)
    Mode: 1280 x 720 x 4294967296 colors
    Video Ram: 256 MB
    Status: OK
    Name: All-in-Wonder X1800XL Secondary
    Processor: Radeon X1800 Series Secondary (0x7129)
    Mode:
    Video Ram: 256 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 41.9 GB
    DeviceID: D:
    FileSystem: NTFS
    FreeSpace: 251 GB
    DeviceID: E:
    FileSystem: NTFS
    FreeSpace: 273 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <SVCD2DVD DateTime="7/23/2006 1:21:11 PM" Filename="NONE"><AssetSet><Asset ID="fd5bf00c-f0e6-4b7d-8d87-24e152ae92ef" Path="D:\" Filename="damian-tftftd-a.mpg" /><Asset ID="426931c0-e054-408a-b228-3344ac861edb" Path="D:\" Filename="damian-tftftd-b.mpg" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="49" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="damian-tftftd-a.mpg" AssetID="fd5bf00c-f0e6-4b7d-8d87-24e152ae92ef" MplexOffset="0" /><Title Name="damian-tftftd-b.mpg" AssetID="426931c0-e054-408a-b228-3344ac861edb" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="E:\program files\svcd2dvd\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="D:\dvd temp" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="False" /><Menu AudioEncoding="Custom_ac3" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="True" SkipAC3="True" PanSan="False" MergeTitles="True" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="NONE" DVDDrive="PLEXTOR DVDR PX-716AL " NeroWriteSpeed="Max" Eject="True" HighDVDCompat="True" VerifyDVD="False" DVDDecrypterPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" /></Settings></SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 794 MB
    file=D:\damian-tftftd-a.mpg
    FormatName=mpeg
    Num_Frames=72924
    DurationInSecs=2916
    Duration=00:48:36.9
    VideoCodec=mpeg2video
    Width=480
    Height=576
    Standard=PAL
    BitRate=2283
    AudioStreamCount=1
    Audio1StreamID=[0x1c0]
    Audio1SampleRate=44100
    Audio1Codec=mp2
    Audio1BitRate=224
    Audio1Channels=2
    Processing damian-tftftd-a.mpg
    13:21:11: Converting PAL to NTSC (SVCD Profile)
    Using low bitrate matrices
    13:21:12: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    13:21:12: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    13:21:12: libavutil version: 49.0.0
    13:21:12: libavcodec version: 51.4.0
    13:21:12: libavformat version: 50.2.1
    13:21:12: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    13:21:12: Input #0, mpeg, from 'D:\damian-tftftd-a.mpg':
    13:21:12: Duration: 00:48:36.9, start: 0.733356, bitrate: 2283 kb/s
    13:21:12: Stream #0.0[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 480x576, 2520 kb/s
    13:21:12: Output #0, dvd, to 'D:\damian-tftftd-a_S2D.mpg':
    13:21:12: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 480x480, q=1-31, 3000 kb/s
    13:21:12: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    13:21:12: Stream mapping:
    13:21:12: Stream #0.0 -> #0.0
    13:21:12: Stream #0.1 -> #0.1
    13:35:33: [mpeg2video @ 0068E248]ac-tex damaged at 3 25
    13:35:33: [mpeg2video @ 0068E248]Warning MVs not available
    13:35:33: [mpeg2video @ 0068E248]concealing 330 DC, 330 AC, 330 MV errors
    13:35:33: video:1067751kB audio:159497kB global headers:0kB muxing overhead 2.474819%
    File Size: 769 MB
    file=D:\damian-tftftd-b.mpg
    FormatName=mpeg
    Num_Frames=72749
    DurationInSecs=2909
    Duration=00:48:29.9
    Width=480
    Height=576
    Standard=PAL
    BitRate=2216
    AudioStreamCount=1
    Audio1Codec=mp2
    Audio1BitRate=128
    Audio1Channels=2
    Processing damian-tftftd-b.mpg
    13:35:33: Converting PAL to NTSC (SVCD Profile)
    13:35:33: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    13:35:33: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    13:35:33: libavutil version: 49.0.0
    13:35:33: libavcodec version: 51.4.0
    13:35:33: libavformat version: 50.2.1
    13:35:33: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    13:35:33: Input #0, mpeg, from 'D:\damian-tftftd-b.mpg':
    13:35:33: Duration: 00:48:29.9, start: 0.733356, bitrate: 2216 kb/s
    13:35:33: Stream #0.1[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 480x576, 2520 kb/s
    13:35:33: Output #0, dvd, to 'D:\damian-tftftd-b_S2D.mpg':
    13:35:33: Stream #0.0, 25.00 fps(c): Video: mpeg2video (hq), yuv420p, 480x480, q=1-31, 3000 kb/s
    13:35:33: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    13:35:33: Stream mapping:
    13:35:33: Stream #0.1 -> #0.0
    13:35:33: Stream #0.0 -> #0.1
    13:50:02: [mpeg2video @ 0068E248]ac-tex damaged at 14 15
    13:50:02: [mpeg2video @ 0068E248]Warning MVs not available
    13:50:02: [mpeg2video @ 0068E248]concealing 630 DC, 630 AC, 630 MV errors
    13:50:02: video:1065811kB audio:159126kB global headers:0kB muxing overhead 2.471242%
    Merging TitleSet #1
    Merging: damian-tftftd-a_S2D.mpg
    Merging: damian-tftftd-b_S2D.mpg
    Correcting PTS values: damian-tftftd-a_S2D_VTS.mpg
    13:52:19: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    13:52:19: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    13:52:19: libavutil version: 49.0.0
    13:52:19: libavcodec version: 51.4.0
    13:52:19: libavformat version: 50.2.1
    13:52:19: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    13:52:19: Input #0, mpeg, from 'D:\damian-tftftd-a_S2D_VTS.mpg':
    13:52:19: Duration: 00:48:29.9, start: 0.500000, bitrate: 7074 kb/s
    13:52:19: Stream #0.0[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 480x480, 3500 kb/s
    13:52:19: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    13:52:19: Assuming PAL for target.
    13:52:19: Output #0, dvd, to 'D:\damian-tftftd-a_S2D_VTS_PTS.mpg':
    13:52:19: Stream #0.0, 25.00 fps(c): Video: mpeg2video, yuv420p, 480x480, q=2-31, 3500 kb/s
    13:52:19: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    13:52:19: Stream mapping:
    13:52:19: Stream #0.0 -> #0.0
    13:52:19: Stream #0.1 -> #0.1
    13:53:12: error, non monotone timestamps 262566000 >= 262481040
    13:54:03: video:2133594kB audio:318623kB global headers:0kB muxing overhead 2.471641%
    PAL->NTSC: demuxing damian-tftftd-a_S2D_VTS_PTS.mpg
    13:54:04: FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    13:54:04: configuration: --enable-a52 --enable-gpl --enable-memalign-hack --disable-debug --enable-pthreads
    13:54:04: libavutil version: 49.0.0
    13:54:04: libavcodec version: 51.4.0
    13:54:04: libavformat version: 50.2.1
    13:54:04: built on Mar 14 2006 17:24:07, gcc: 3.4.4 (mingw special)
    13:54:04: Input #0, mpeg, from 'D:\damian-tftftd-a_S2D_VTS_PTSPAL.mpg':
    13:54:04: Duration: 01:37:06.4, start: 0.500000, bitrate: 3533 kb/s
    13:54:04: Stream #0.0[0x1e0], 25.00 fps(r): Video: mpeg2video, yuv420p, 480x480, 3500 kb/s
    13:54:04: Stream #0.1[0x80]: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    13:54:04: Output #0, rawvideo, to 'D:\damian-tftftd-a_S2D_VTS_PTSPAL.mpv':
    13:54:04: Stream #0.0, 25.00 fps(c): Video: mpeg2video, yuv420p, 480x480, q=2-31, 3500 kb/s
    13:54:04: Output #1, ac3, to 'D:\damian-tftftd-a_S2D_VTS_PTSPAL.ac3':
    13:54:04: Stream #1.0: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    13:54:04: Stream mapping:
    13:54:04: Stream #0.0 -> #0.0
    13:54:04: Stream #0.1 -> #1.0
    13:54:49: error, non monotone timestamps 262483200 >= 262481040
    13:55:31: video:2133594kB audio:318623kB global headers:0kB muxing overhead -12.993248%
    13:55:31: PAL->NTSC: Applying Pulldown damian-tftftd-a_S2D_VTS_PTSPAL.mpv
    13:55:31: SVCD2DVD: Convert2NTSC: Converting....
    14:02:42: PAL->NTSC: Muxing damian-tftftd-a_S2D_VTS_PTS.mpg
    14:05:59: INFO: [???] mplex version 2.0.0 (2.2.3 $Date: 2004/01/13 20:45:26 $)
    14:05:59: INFO: [???] File D:\damian-tftftd-a_S2D_VTS_PTSPAL_pd.mpv looks like an MPEG Video stream.
    14:05:59: INFO: [???] File D:\damian-tftftd-a_S2D_VTS_PTSPAL.ac3 looks like an AC3 Audio stream.
    14:05:59: INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    14:05:59: INFO: [???] Found 1 audio streams and 1 video streams
    14:05:59: INFO: [???] Selecting dvdauthor DVD output profile
    14:05:59: INFO: [???] Multiplexing video program stream!
    14:05:59: INFO: [???] Scanning for header info: Video stream e0 (D:\damian-tftftd-a_S2D_VTS_PTSPAL_pd.mpv)
    14:05:59: INFO: [???] VIDEO STREAM: e0
    14:05:59: INFO: [???] Frame width : 480
    14:05:59: INFO: [???] Frame height : 480
    14:05:59: INFO: [???] Aspect ratio : 4:3 display
    14:05:59: INFO: [???] Picture rate : 29.970 frames/sec
    14:05:59: INFO: [???] Bit rate : 3500000 bits/sec
    14:05:59: INFO: [???] Vbv buffer size : 229376 bytes
    14:05:59: INFO: [???] CSPF : 0
    14:05:59: INFO: [???] Scanning for header info: AC3 Audio stream 00 (D:\damian-tftftd-a_S2D_VTS_PTSPAL.ac3)
    14:05:59: INFO: [???] AC3 frame size = 1792
    14:05:59: INFO: [???] AC3 AUDIO STREAM:
    14:05:59: INFO: [???] Bit rate : 57344 bytes/sec (448 kbit/sec)
    14:05:59: INFO: [???] Frequency : 48000 Hz
    14:05:59: INFO: [???] SYSTEMS/PROGRAM stream:
    14:05:59: INFO: [???] rough-guess multiplexed stream data rate : 4041144
    14:05:59: INFO: [???] target data-rate specified : 10080000
    14:05:59: INFO: [???] Setting specified specified data rate: 10080000
    14:05:59: INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    14:05:59: INFO: [???] New sequence commences...
    14:05:59: INFO: [???] Video e0: buf= 0 frame=000000 sector=00000000
    14:05:59: INFO: [???] Audio bd: buf= 0 frame=000000 sector=00000000
    14:05:59: ++ WARN: [???] Stream e0: data will arrive too late sent(SCR)=262627474 required(DTS)=0
    14:05:59: ++ WARN: [???] Video e0: buf= 175335 frame=072953 sector=00542464
    14:05:59: ++ WARN: [???] Audio bd: buf= 15453 frame=091193 sector=00081061
    14:05:59: INFO: [???] STREAM bd completed @ frame 182069.
    14:05:59: INFO: [???] STREAM e0 completed @ frame 145694.
    14:05:59: INFO: [???] Multiplex completion at SCR=524470710.
    14:05:59: INFO: [???] Video e0: buf= 212764 frame=145694 sector=01083821
    14:05:59: INFO: [???] Audio bd: buf= 0 frame=145686 sector=00161841
    14:05:59: INFO: [???] VIDEO_STATISTICS: e0
    14:05:59: INFO: [???] Video Stream length: 2184799775 bytes
    14:05:59: INFO: [???] Sequence headers: 9715
    14:05:59: INFO: [???] Sequence ends : 0
    14:05:59: INFO: [???] No. Pictures : 145695
    14:05:59: INFO: [???] No. Groups : 9715
    14:05:59: INFO: [???] No. I Frames : 9715 avg. size 32118 bytes
    14:05:59: INFO: [???] No. P Frames : 38853 avg. size 20552 bytes
    14:05:59: INFO: [???] No. B Frames : 97128 avg. size 11060 bytes
    14:05:59: INFO: [???] Average bit-rate : 2998800 bits/sec
    14:05:59: INFO: [???] Peak bit-rate : 5708400 bits/sec
    14:05:59: INFO: [???] BUFFERING min 15 Buf max 197831
    14:05:59: INFO: [???] AUDIO_STATISTICS: bd
    14:05:59: INFO: [???] Audio stream length 326269440 bytes.
    14:05:59: INFO: [???] Frames : 182070
    14:05:59: INFO: [???] BUFFERING min 35 Buf max 7203
    14:05:59: **ERROR: [???] MUX STATUS: Frame data under-runs detected!
    14:05:59: Done: Processing assets for DVD creation
    Authoring DVD Folders
    14:06:00: Creating TitleSet # 1
    14:06:00: SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    14:06:00: -->: DVDFolders creating VTS
    14:06:00: -->: VTS 01
    14:06:00:
    DVD Folders: Processing D:\damian-tftftd-a_S2D_VTS_PTS.mpg...
    14:07:31:
    14:08:11:
    14:08:11: Finalising DVD...
    14:08:11: SVCD2DVD: DVDfolders
    14:08:11: -->: DVDFolders creating table of contents
    14:08:11: scanning D:\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
    14:08:11: Finalising DVD...Done
    14:08:11: Done: Authoring DVD Folders
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Have you tried NOT merging the titles?
