hello
which file do I have to add to VobEdit in order to demux a VIDEO_TS?
thanks
All VOB's except VIDEO_TS.VOB .
BTW...Make sure you go to Explorer->Tools->Folder Options->View and untick "Hide extensions....",it's also wise to select "Show hidden files and folders". -
All VOB's except VIDEO_TS.VOB ?
I will have to load them one by one? ctrl+a doesnt work, I cannot find a way to load multiple files.. -
Wrong ...
If it is the main title you wish to demultiplex , load it's first vob only .
If main title vob id is say , vts_06_01 , then you only need to load it , not all of them .
When you sellect "demux" option , in new box , sellect item you wish to rip out .
Down below is the option box "demux complete title set" , check it .
What will happen now is the chosen part will be ripped to a folder , from vts_06_01 , vts_06_02 , vts_06_03 , and so on , till all vts_06 vob's have been completed .
Demultiplexing everything will make a complete mess , and most likely screw thing's right up if you dont know what you are doing ... ie , movie title , and menu's should be dealt with as individual component's ... not as a whole ... do it the wrong way , and you get a headache from hell ...
In the case of the video_ts , you load video_ts.vob only . -
VIDEO_TS.VOB is the menu,you might be better off(if you still have the DVD) using DVDDecrypter->IFO Mode->Stream Processing.
How to add an mp3 audio file onto an mp4 video file?
By Tintin11 in forum RestorationReplies: 4Last Post: 4th Nov 2010, 06:01 -
Converting a AVI file, want to add another video file
By s_joy09 in forum Authoring (DVD)Replies: 7Last Post: 7th Aug 2010, 14:40 -
Extract from avi file and add to existing mkv file
By pathumx in forum MacReplies: 6Last Post: 8th Apr 2010, 18:57 -
Trying to Join separate files into 1 file, then add 1 more file and burn
By futureBDburner in forum EditingReplies: 2Last Post: 11th May 2008, 03:50 -
add srt file to avi, xvid 700mb movie file
By volam in forum EditingReplies: 2Last Post: 30th Jan 2008, 21:22
