When I captured my Family Guy movies for backups, I noticed that my DVD player skips a lot. It's a GoVideo DVD+VCR Year 2000 model(I forget the model number), is it because I need a newer DVD player? I tried it on my computer and it worked with minimal flaws. Is there a way to convert it to where my DVD player can handle it? I used DVDShrink and SmartRipper for it.
Life is short.
Most likely either the quality of the media or the quality of the media and the age/quality of the player. I suggest this a)because it is the most likely answer, and b)because you say that even on the PC you get glitches ("minimal flaws"). You should get perfect playback on the device that burned it, at the very least.
What media are you using (brand and media code) ?
What do you see if you read test the discs (suggest DVD Info Pro or Nero Speed Disc for this) ?Read my blog here.
Help Finding A High Quality Capture Card
By NMeade in forum Capturing and VCRReplies: 4Last Post: 24th Apr 2010, 20:00 -
Recording with high quality and good conversion methods (snagit & codec q.)
By mukunku in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2010, 23:43 -
From Point & Shoot Digital Camera AVI to Xvid High Quality
By kamil in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 09:28 -
how to capture in very high quality in VirtualDubMod?
By ayyak in forum Capturing and VCRReplies: 5Last Post: 5th Jan 2009, 02:41 -
High quality AVI to MP4 conversion?
By conchord in forum Video ConversionReplies: 14Last Post: 27th Sep 2008, 10:22
