I am transferring old home movies on VHS to my PC. I have a VCR connected to my Canon ZR70 camcorder, the camcorder to my PC via firewire. The capture quality is great, I am using Premiere Elements 2.0 (Using S-Video and regular audio connectors, Red and white)
I noticed during playback the the sound is only comming from my left speaker. I checked the settings on the VCR and the audio is set correctly, I also checked the audiod setup from my camcorder and it is set to both channels. All the cords were plugged in tight and correctly. Any thoughts? Thanks!!!!
Jason
Results 1 to 9 of 9
I justed checked it with Gspot. For the audio it states: (S) --> AVI Splitter --> (R)
I am newer to this but I am guessing it means its only outputting via the right channel?
Is there anyway to have it have both channels? I have taken video with my Camcorder before and captured it to my pc and both channels play audio. Is this issue happening because I am using the camcorder as a passthough to my PC? I have to imagine there is a way to do this? I have checked with my Camcorder manual and I believe I have everything setup correctly, same with the VCR. HELP!
Jason -
No, (R) in this case means (render)
We want to see what the "audio" section say: how many channels? -
You might want to use the newer version of Gspot (2.52), if you have the older one.
Under 'Audio' a Xvid I have says:
Codec: 0x0055(MP3), ISO Stat: Codec(s) Installed
Info: 48000Hz 128kb/s total (2chanls)
That tells me it's a MP3 audio and I have the proper codec. The second line is the sample rate. bitrate, and the (2chnls) tells me it's stereo (Or at least has more than one channel.)
If it does show stereo, then it's probably just a playback problem. But if it only shows one channel, then make sure your audio properties are set correctly. Control Panel>Sounds and Audio Devices Properties>Audio>Sound Recording. This may vary depending on your computer. Usually if you click on 'Volume' there, you will see the control panel. You may also have a speaker icon in your toolbar that you can right click on to get the same control panel. 'Line In' is usually what you are looking for. -
If you demux the audio with virtualdub and open it in an audio editor, what do you see in each channel ?
Read my blog here.
Should I use S-VHS cable for standard VHS transfer?
By Gibson's Squares in forum Newbie / General discussionsReplies: 11Last Post: 16th Feb 2012, 12:50 -
DVD-R sound coming through only one speaker
By Marshfish in forum Newbie / General discussionsReplies: 5Last Post: 7th Sep 2011, 01:40 -
Edited sound jumps from speaker to speaker
By len hend in forum AudioReplies: 3Last Post: 23rd Jul 2010, 05:49 -
How fix mp3 with audio comming out of a single speaker ?
By hiavi in forum AudioReplies: 2Last Post: 17th Sep 2009, 22:28 -
Help: Sound only plays from left speaker
By rdc in forum AudioReplies: 5Last Post: 31st Dec 2007, 21:25
