This is like a $400 capture device, and when I cap football games, usually during a 3 hour game there are at least 3 times when ten seconds of the game is not captured.
My cords are pretty cruddy. Could bad cords be a problem? Thanks.
Results 1 to 13 of 13
As Barnabas suggested, try WinDV or ScenalyzerLive. They both use a memory buffer to eliminate dropped frames. What are your system specs?
3hr transfers (>40GB) may be filling your partition. Also a fragmented drive will cause drops.
You should be transferring to a separate internal drive from the OS and the partition should be reasonably defragmented.
Give more detail. -
RAID is most likely the problem.
RAID sounds good on paper but for video capture it can be tricky to set it up "just right".
I doubt RAID is a problem.Originally Posted by fatty4ksu
During 3hrs or so, the chances are something else is going on with your system such as a device going into sleep mode only to be awakened again. Or you have a scheduled service doing something (like a spyware checker, virus scanner, email etc).
Try disabling all the power management - i.e., don't let Windows turn any of the hard drives off etc. By the way, are the 10 second losses at regular intervals. e.g., if it happens every 60 minutes, that would definitely point to the behind-the-scenes power management.John Miller -
I am only guessing when I said it could be a RAID problem but RAID is not GOD ... I have seen many people have issues with a RAID system when doing captures/transfers of analog/digital video.
It is a valid issue to "look into".
A single RAID containing the OS may be a fine gamer setup but video apps gain reliablity when drives are separated into OS operations and separate video capture.
Normal practice is to use a small drive for the OS + applications and a separate drive or RAID for video capture and processing. A single ATA-100 drive is plenty fast enough for DV video. Most sytems are fast enough to handle Huffyuv with a single drive. If you are running full SDI uncompressed then you will need a RAID. Just keep the OS off the RAID. -
fatty4ksu,
Are you capturing from VHS tapes ??
I can't think of *ANY* reason why you are having frame drop issies.. assuming
that you are capturing from satellite or cable. I think that you are capturing
from a VCR, and the source is vhs tapes. If you are, then its probably a host
of things that is causing your frame drops. But, one of the main things that
*could* cause frame drops (from vhs tapes) is the vcr's tracking. Say you had
recorded from an old vcr, and now, you have a new (or different) one, this could
be your problem, where your *other* vcr's tracking is not matching the same, as
your original vcr(s) used for those vhs tapes. You could have used a number of
vcr's during those vhs tape recordings.. and over the years.
Course, this is all based on the assumption that your sources are vhs tapes
(and, you left that fact (though, very important) out)
-vhelp 4078 -
Please ... my ego is big enough as it is ... LOL 8)Originally Posted by bendixG15
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
ADVC-300 Adjusting Image Settings - Need another ADVC?
By MitchJi in forum RestorationReplies: 0Last Post: 1st Apr 2009, 13:36 -
JVC HM-DH30000U + ADVC-110 or ADVC-300
By cadguy4u in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 14:29 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15 -
ADVC-300
By fatty4ksu in forum Newbie / General discussionsReplies: 12Last Post: 4th Jun 2007, 22:52
