Is there a program that will let me load my home made DVDs back on to computer and then re-edit with a program like Pinnacle Studio.
Results 1 to 14 of 14
dvd decrypter. Or any ripper program really. Since its home made theres no protection to worry about.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Originally Posted by yoda313
E 09:49:56 [0:0:0] HL-DT-ST DVDRAM GSA-4163B A104 (E- UDF File System Parsing Failed!
E 09:49:56 Reason: Function 'UDFFindPartition' returned 0
I need to be able to edit in Pinnacle Studio
Any help please -
Try any other ripper. Dvd shrink for example. Also could it be a scratched disc maybe? Sometimes that makes it hard for a ripper to get the whole disc.
Pinnacle Studio will directly rip MPEG out of a DVD, at least in version 9.4.3 (the one I heve)so I suppose version 10.xxx will also do (wich doesn´t mean Studio is not a buggy and crash-happy prog.)
Originally Posted by kschang
So I've ripped one of my non copyright DVDs to HD, and I have a Video-TS file.
It won't load into Pinnacle Studio.
What can I try next? -
P.S.
My cousin was a director on the Xmen movies.(And the Fantastic Fours) -
Originally Posted by fritzi93
Any more suggetsions please -
I have Studio 9.35 and it does edit mpeg2. So did version 9.1.
The "photoshoot" sample files that come with the program are mpeg.
What has been a problem for me is if I try to use a file that has AC3 audio, because I'm too cheap and stubborn to give pinnacle any more cash and activate Dolby/AC3 sound.
What kind of audio does your vob have?
Another thing you could try is to load the vob into VirtualDub-MPEG2 and then save it out as a DV-avi (install the Panasonic DV codec to do that easily) with PCM Wav audio, I've done that with some vob's that had AC3 sound, and they loaded into Studio 9 just fine.
Granny
EDIT --- ADDED
Do you have MPEG2 encoding activated for Studio?It's free, just follow the steps in the help file to go to their website to get your free activation code. -
didikai, here is another piece of information that might apply to your problem.
Studio 9.35 and below do not support progressive scan / non-interlaced mpeg2 / vob type files, only interlaced.
here is link to the FAQ
You might need to upgrade to v 9.4 if you don't want to re-encode your mpeg2 to avi.
hope this helps
Granny -
TMPGEnc DVD Author can read straight from VIDEO_TS folder (or several) and Author a DVD containing anything from the source VIDEO_TS folders to another VIDEO_TS folder which can then be directly burned to a disc, even from within the application itself. I do it all the time.
MKV file audio out of sync on my computer, inferior computer plays perfect
By dave in or in forum Newbie / General discussionsReplies: 7Last Post: 5th Aug 2011, 21:56 -
How to copy dvd movies to computer and build a liabrary on the computer
By robrpb in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2010, 18:16 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
Capturing Halo 3 gameplay from computer monitor to computer
By Jamo in forum Capturing and VCRReplies: 1Last Post: 13th Oct 2007, 00:06
