ok ive been using dvd shrink to copy and burn my movies. and all the movies i copy are well over 5 gigs so i have to end up just burning the movie itself without all the extras to fit it on one disc.
so my question is what program can i use to cut an iso file in half so i can put it on 2 discs? just the movie itself, but i also want to have the dvd menu + extras
any info or help would be appreciated
Open the ISO with DVD Shrink.
He's a liar and a murderer, and I say that with all due respect. -
ok so ive done it, it just compressed the entire dvd so it would fit on a 4.7gb disc...
is it just me or has the quality gone down quite a bit? -
open the iso in DVDShrink, goto the reauthor tab and drag the movie over to the left under dvd structure. Then click on the set start/end frames, Select the first half of the movie, lets say chapters 1-15, then backup and save the new iso as part one, then go back and choose 16-30 then save the next iso as part two.
I'm sure there is a better guide to the left......
Here's a guide that explains the cutting alittle better
http://www.dvdshrink.info/splitting-v2-3.php
Post 2000
well i didnt even have to do that
it was a 7.5 gig disc, but when i opened the iso file with dvd shrink it made it so it would fit on one disc, extras and all
but the quality looked worse.. is that why? -
Because anytime you transcode a file(eg MPEG,MP3) to make it smaller you lose some quality,some data must be discarded.There are some things you can do to improve visual quality:enable Deep Analysis,enable AEC,select the movie only.Originally Posted by NateDizzle
My rule is:if I have to compress more than 35% I split to two discs. -
ok so yeah, i burned one with a shittier quality but with all the extras and everything... but then i went ahead and just burned the movie itself, quality was near perfect, so better quality with less extra crap, yes?
so now that i know, ill be just burning the movie itself, thats all i need, i never even watch extras kinda pointless............
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
1080i .TS Video file to Blu-ray .ISO file Help !
By SiNnOFf in forum Authoring (Blu-ray)Replies: 19Last Post: 3rd Nov 2010, 13:12 -
ISO file bigger than original video_ts file.
By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 19:04 -
Why Does ImgBurn Only Sometimes Build an MDS File with ISO File?
By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 13th Aug 2009, 23:36 -
convert iso file back to vob file
By cda62 in forum Newbie / General discussionsReplies: 2Last Post: 9th Jan 2008, 12:50
