anyone knows what this means and if it can be fixed
Could mean that some of Nero's filters aren't registered, could also be a lack of 3rd party filters to complete the graph. Can you play the file ok?
I've seen the same error. In my case it was PowerDVD giving the error. I had burned the disc (a Ritek G05) with DVD Decrypter using a DVD Shrink image. Right at the end of the burn, the burner (a Pioneer 107) drive chamber mysteriously opened, then immediately closed. PowerDVD gives me the error and then after clicking OK, no longer recognizes there is a disc in the drive. The disc also fails on my Panny RP62 player. Oddly enough, I could then turn right around and sucessfully burn the image using Nero.
I decided it was probably some sort of media error or incompatiblity, but was never able to conclusively track down the problem. It never happened with any sort of reproducible regularity.
what does this mean 'pins in the graph' RE: FLV file.
By talx in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2011, 12:26 -
frequency response graph
By siluet in forum AudioReplies: 13Last Post: 10th Feb 2010, 14:11 -
Opening files in Graph Edit
By tb582 in forum Newbie / General discussionsReplies: 1Last Post: 7th Aug 2009, 13:27 -
Free bar graph software?
By PGibbons in forum Newbie / General discussionsReplies: 1Last Post: 7th Mar 2009, 14:06 -
AC3 graph problem.
By jkleslie in forum AudioReplies: 1Last Post: 20th Dec 2007, 10:45
