I am trying to capture with a Dazzle II using the SVCD template. I was told that while the bitrate says one thing it really is much lower. to fix this you need to raise the settings in the template from 2400000 to closer to 4000000. in order to then fit it onto a CD i changed it to 3100000 and i get 45 minutes. what i am confused about is the bitrate i am really getting as a result. when i run it through bitrate.exe i see a NOM bitrate of 3100000 but an avg bitrate of 1524?? this makes me think the bug is really in Dazzle and 3100000 really means something lower. so now the real question is a 1524 bitrate in SVCD better worse than 1600 bitrate in VCD?? the picture seems better but maybe i am just seeing whats not really there?
Results 1 to 1 of 1
Capture issue with Dazzle and Vista 64bit. HELP!!!!!!!!!!!!!!
By dking in forum Capturing and VCRReplies: 4Last Post: 21st Jul 2009, 18:48 -
dazzle capture card help
By brian2391 in forum Capturing and VCRReplies: 1Last Post: 2nd Mar 2009, 10:45 -
Help with Dazzle Capture Card
By x420x Lovin in forum Capturing and VCRReplies: 6Last Post: 30th Sep 2008, 12:14 -
what other programs can I use for a Dazzle capture device
By reniett in forum Capturing and VCRReplies: 2Last Post: 8th Sep 2008, 00:08 -
Capture with Dazzle DVC170 with another program?
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 19th Jul 2007, 08:53
