Hi,
I have 2 files each one of 700 MB and would like to create a DVD. Usually I use MPEG encoder and then TMPGenc DVD autho but in this case I don't know how to use them.
Any EASY suggestion? Is that possible to put two 700 MB in one single DVD?
Thanks a lot in advance/Fabio
Why won't your usual method work?
You could use VirtualDub to append one to the other. Open the first file in VirtualDub, then go to File and select "Append AVI Segment" and point it towards the second file. Set both audio and video to "Direct Stream Copy", then go to File and save it as an AVI. Provided it is possible to append them, you'll get one big AVI file out. Put that through your usual encoding process to get one long video. -
Thanks a lot but a message appears:
couldn't locate decompressor for format XVid ( unknown) -
Use avicodec to determine what is missing, but chances are you don't have the latest Xvid codec install, but something like FFDShow. You can therefore play it in WMP, but not process it in virtualdub.
Read my blog here.
Sure just make sure you keep the bitrate low enough to fit a single layer dvd. That is assuming you are in fact converting to mpeg2 and then authoring a normal dvd as you said.Originally Posted by marlo
The other option is to buy a dvd player that reads divx files and simply burn the avi's to dvd as data. Then it will play them without having to encode them to dvd.
Another option is a realtime option. If you have a realitvely slow computer and encoding from avi to mpeg takes awhile you can use a capture card.
Simply hook up another computer to the video and audio in on your capture card and record to a dvd profile in mpeg2 mode. Then you can author right away since it will now be in mpeg 2 after the realtime capture. Though you will lose 5.1 audio if you do this method. You'd have to split the audio off the original avi and mix it in with the new mpeg. Though you may have synch issues unless you can match the realtime recording of the avi to the exact time of the avi on the new mpeg.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Copying separate files from dvd's
By Peter1954 in forum Video Streaming DownloadingReplies: 1Last Post: 15th Dec 2011, 08:15 -
how to link togerther some .avi files to create a dvd
By marlo in forum MacReplies: 2Last Post: 10th Jul 2011, 06:12 -
Hoe to create a DVD menu with link to AVI files
By OggO1984 in forum Newbie / General discussionsReplies: 3Last Post: 14th Dec 2009, 16:01 -
Video Noob - how to create dvd for dvd player from avi, flv files..?
By acegap in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 08:10 -
Can't switch between separate dvd-files
By SirTarhan in forum Newbie / General discussionsReplies: 8Last Post: 27th Mar 2008, 04:16
