first of all im kind of a newbie when it comes to this. not sure if i'm even putting this in the right forum. but i videotaped some stuff using my panasonic dv camcorder. got it hooked up to my pc via firewire. i can watch the stuff i've videotaped or use it as a webcam, but how do i save it to avi so i can edit it and such?
WinDV can transfer it to your HDD into an AVI file (13GBs per hour of footage), as can Windows Movie Maker. Chances are you received a disc with either your camera or firewire card that may also have an editing program on it. It might be worth digging out.
WMM can be used to edit your footage, but it can only output WMV or DV avi.
What do you intend to do with the edited footage ?Read my blog here.
Lofty ambition. You may want to consider getting some better software then.i intend to architect cinematic masterpieces.
Beginner to moderate needs : Premiere Elements or Vegas Movie Studio, or perhaps Video Studio from Ulead.
More ambitious to semi-pro : Premiere Pro or Vegas
You also need to look at authoring software if you intend to finish up on DVD.
You should also consider upgrading your RAM to 1GB, and adding a second HDD. Another 120GB would be a good start.Read my blog here.
lofty ambition indeed! i can't help it man, i'm a johnny.
according to kabalarian philosophy, people named johnny:
"have large ambitions, and it is difficult for you to be tolerant and understanding of those who desire less in life or who are more slow and methodical by nature.
do, however, have leadership ability and would never be happy in a subservient position.
are ambitious and aggressive by nature.
would be happiest in positions where you are free to express individually and creatively and where opportunities are not restricted; you desire freedom, and do not tolerate being possessed by others. :P
appreciate change and travel, and the opportunity to meet and mix with others, and to influence them with your creative ideas."
not to mention i'm an aquarius. :P
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
