ok heres the deal i want to make halo 2 videos.i have An avermedia Ezdvd maker pci i installed drivers and all i have sony vegas.theres the wire that goes into the pci card its connected the end of that wiire is composite(yellow and red)its goes in the imput of of vcr(line 1) then my xbox 360 goes in line 2 input and the composite wires(Different from what i mention ealrier)r in output line 1 going to tv
First, you need to be more specific. Most TV cards have multiple inputs which can all be connected at the same time. You choose which imput you want to watch/record from within the software supplied with the card.
After you get everything connected and you are able to view all of your inputs within your display software, then you can begin figuring out how to capture.Google is your Friend
Capturing problem
By Phoenix 37 in forum Capturing and VCRReplies: 4Last Post: 18th Jun 2011, 17:09 -
Problem Capturing DV with Windows 7
By monoxide77 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 9th Jun 2009, 14:31 -
VHS Capturing Problem
By sdculp in forum Capturing and VCRReplies: 14Last Post: 12th Feb 2008, 15:08 -
DV capturing problem
By BMR in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Sep 2007, 16:19 -
Capturing Problem.
By rowie4life in forum Capturing and VCRReplies: 1Last Post: 20th Aug 2007, 08:33
