Results 1 to 27 of 27
    Jul 2006
    Belgium
    I have a .BIN file and I want to put subtitles
    How to do please?
    Thank you
    a bin file is an image file, no video format.
    but it is probably a vcd a svcd. then extract the video with isobuster and add subs with for example virtualdub and vsfilter plugin.
    Jul 2006
    Belgium
    Can you tell me how to extract with isobuster please?
  4. Member steveryan's Avatar
    Jan 2003
    Manchester
    He's a liar and a murderer, and I say that with all due respect.
    Sep 2005
    Spain
    He already did: https://www.videohelp.com/forum/userguides/159399.php
    Why not try the guides - it might help.
    Jul 2006
    Belgium
    ok i make a MPEG file with isobuster : Do I keep like this ?
    Nov 2002
    Then you author the MPEG with your subtitles to a new disc image or a new disc.
    Jul 2006
    Belgium
    And how to author WITH the subtitles
    I have converted in AVI with virtuadub the mpeg , but with VLC i don't see subtitles
    Sep 2005
    Spain
    You can load your subs with mplayerc.exe (among others).
    Or you can use a filter with Vdub. See "How to add permanent subtitle to a video with virtualdubmod" (https://www.videohelp.com/forum/viewtopic.php?t=272736)
    Jul 2006
    Belgium
    is it normal that the AVI converted make only 4 Mo ???
    Jul 2006
    Belgium
    forget the previous post
    But when I have my AVI, VLC doesn'y follow the subtitles
    If for example i change the video it works but not with that one
    If I take another BIN and that I convert it is the same thing
    There's something wrong no?
    Nov 2002
    You loaded and turned on subtitles, yes?
    Jul 2006
    Belgium
    sorry?
    Nov 2002
    In VLC, you turned on subtitles, when you open AVI, yes?
    Jul 2006
    Belgium
    Yes of course
    Nov 2002
    So what happened when you tried MPC instead?
    Jul 2006
    Belgium
    MPC tell me that I must change the render video : how to do that?
  18. Member
    Nov 2002
    Edit / Settings, I think, then search for video renderer settings. Only some support subtitles.
    Jul 2006
    Belgium
    I don't find EDIT ...
    Nov 2002
    Sorry, it's View / Options
    Jul 2006
    Belgium
    Ok and how to change video renderer ?
  22. Member
    Nov 2002
    Oh, come on, check the choices a little, it's got to be under video...
  23. Member
    Jul 2006
    Belgium
    In fact I don't understand what means to change the renderer et I don't see that in the options ...
  24. Member
    Sep 2005
    Spain
    Neither do I, but try "Output" under "Playback". And do show some initiative, are you employed by the Belgium State?
  25. Member
    Jul 2006
    Belgium
    No I work in France but leave (live?) in Belgium
    Nothing work kshang
  26. Member
    Nov 2002
    You close the program and restart program after making change, yes?
  27. Member
    Jul 2006
    Belgium
    Yes I doesn't change anything
