I have converted files using winavi to dvd format, these files are 4:3 ratio, I put them in dvdlab to make them into a nice dvd with menus and converted it but when i play it on my 27" tv the subs get cut off, i tried changing the aspect ratio to 16:9 in winavi but that just chopped part of the picture and then there were no subs, is there a way to shrink the picture so the subs are moved up??
Are they just cut off at the bottom? Cuz you can use dvdsubedit on the vob files to move the subs up.
Dvd-lab Read Data Size
By Burig in forum Authoring (DVD)Replies: 14Last Post: 19th Oct 2011, 20:41 -
DVD-lab frame size
By Burig in forum Authoring (DVD)Replies: 4Last Post: 17th Oct 2011, 12:27 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 15:48 -
video size quadruples in dvd lab pro
By YOURCONNEXX in forum Authoring (DVD)Replies: 1Last Post: 13th Mar 2008, 20:23 -
[ERR] GOP size is over the buffer limit - Compiling in DVD-lab PRO 2.30
By Wolverene in forum Authoring (DVD)Replies: 7Last Post: 31st Aug 2007, 23:55
