When I try to load a project which was created with DVDAuthorGUI I get this error message:
Run-Time Error '9':
Subscript Out of Range
Can anyone tell me what is causing this and what I can do to correct it and access my project? The file name is "DVDAuthoredGUI Project.dva" and it resides in the folder which contains the VIDEO_TS and AUDIO_TS folders.
Thanks in advance for your help.
GB Packers fan for life! Go Pack!
That appears to be a Windows error, not necessarily from DVDAuthorGui. Paraphrased from a Excel site:
The Runtime error 9, Subscript Out of Range may occur if any of the parts have been renamed and therefore the program cannot reference them when processing the output.
The number of independent variables that can be run is limited to 10 in order to maintain reasonable processing times on slower computers.
My take on that is that you may have a naming error in one of the files or the file name has been changed since the project file was created. Check them for unnecessary spaces or odd characters and see if anything is different since you made the project file. This could also occur if you have a corrupted file, but a name change is the main suspect. -
email me the project, and I would be happy to diagnose the problem for you.
liquid_217@hotmail.com -
I don't think that it's a corrupt file, since this has happened numerous times. I didn't change the name of the project file or the path. At one point, I too thought it was because I had changed the path (which I had at that time - it was a different project than this one). In my research I hadn't found the reference to Excel, thanks for pointing that out. I do have spaces in my path, I can replace those with underscores and see if that makes a difference.This could also occur if you have a corrupted file, but a name change is the main suspect
Do you need just the .dva file? Or, should I send the VIDEO_TS and AUDIO_TS folders also?email me the project, and I would be happy to diagnose the problem for youGB Packers fan for life! Go Pack! -
Don't edit the paths quite yet. All I need is the project file.
Even though I had version DVDAuthorGUI 1.008b loaded, I was still getting the "Subscript Out Of Range" error. So, to be on the safe side, I removed DVDAuthorGUI from my computer and then redownloaded and installed version 1.008b again.
Solved the problem! Works like a charm.
Thanks to everyone for your help. Wish all solutions were this simple.
ImgBurn Error "Logical Block Address Out of Range"
By SoberWarlock in forum Authoring (Blu-ray)Replies: 3Last Post: 4th Dec 2011, 16:37 -
HVX 200 P2 - Time Lapse "Recording Error" now file wont play or import!
By trevmarps in forum Capturing and VCRReplies: 1Last Post: 26th Apr 2010, 16:15 -
By trevmarps in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Apr 2010, 17:08 -
DVDAuthorGui run-time error 75
By boborg in forum Authoring (DVD)Replies: 4Last Post: 16th Jan 2009, 15:37 -
RIAA ON THE RUN "about time "
By NICEBUD in forum Latest Video NewsReplies: 2Last Post: 14th Mar 2008, 10:32
