Results 1 to 11 of 11
    Feb 2005
    EARTH
    hello
    is there a nice way to remove trailers, fbi warnings, disclaimers, generaly all annoying things, apart from main movie,menus,extras ?
    I tried with vobblanker but its so complicated
    a nice tool that would enable me to preview and delete would be best
    any hint?
    thanks
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    dvdshrink and select main movie only.
  3. Member ntscuser's Avatar
    Mar 2003
    That would also remove the menu and extras. Never had any problem previewing and deleting unwanted files with VobBlanker myself.
  4. Invest more time in learning VobBlanker, and follow a step-by-step guide. IMO, it's the best tool for the scenario you describe. VobBlanker is not all that difficult, and will repay your effort.
    Pull! Bang! Darn!
    Feb 2005
    EARTH
    I found DVD Shrink to be the best
    it allows me to easily preview each part of the dvd
    but does it have an option to remove it? I only found an option to replace with a picture, while I would like to completely remove some dvd parts
    is it possible with DVD Shrink ?
  6. Member ntscuser's Avatar
    Mar 2003
    The problem with replacing a video segment with a still-frame is that the still-frame will be displayed for the same amount of time that the original video segment lasted.
    Feb 2005
    EARTH
    yes, thats what I was afraid of
    so I cannot remove certain stuff from a dvd using DVD Shrink ?
  8. Member ntscuser's Avatar
    Mar 2003
    Not without totally re-authoring. As a rule it's best to remove as much as possible with VobBlanker before opening in Shrink. That means Shrink has less work to do and picture quality is maximised.
    Feb 2005
    EARTH
    I have problems with VobBlanker, it doesnt recognize a part of the dvd that contains a copywrite warning, which is under 'extras' in DVDShrink
    maybe another re-authoring program would do it
  10. Member ntscuser's Avatar
    Mar 2003
    You can use VobBlanker to edit bits from the start of the main movie file such as warning notices and company logos but be warned there can be undesirable side effects such as when a commentary begins before the opening titles have appeared.
