everytime i try to add subtitles to the movies it just doesnt appear.
i add subtitle channel to the movie but still not working,,
do i have to install plugin or something to make it work ??
any ideas please,,
i have the latest version of the program VSO ConvertXtoDvd
what kind of subtitles do you have?
how do you check the subtitles? you may have to manually switch on the subtitle track in the dvd player. -
thanks for replying me
i tried it with srt,sub and idx, all subtitles that VSO supports, i asked someone about this problem and he told me that it works fine all you need is to push Subtitle button on the remote of ur DVD player but i havent tried it u,, have you ?? -
yes, VSO creates *selectable* subtitles, which means you have to tell your dvd player to use them
via your remote. Try it & see. -
Hi,
I confirm, all you need to do is hit the subtitle button on your remote control.
To make sure you added your subs correctly you can take a look at the log file or at this mini guide to see if this is what you did http://www.vso-software.fr/faq/add_subtitles_to_dvd/add_subtitles_to_dvd.php
In the 2.0.15 version you can select a default subtitle to appear (so that way you do not have to press the subtitle button). To do this, click on subtitle file (beneath what is selected in figure 2 in guide above) right click and select "set as default subtitle". -
thanks alot guys,, it was really helpful,, i will try both ways,, thanks again
VSO ConvertXtoDVD is turning 155 mins into 95
By Calavera33 in forum Video ConversionReplies: 7Last Post: 25th Apr 2011, 11:32 -
subtitles and convertxtodvd
By babeflover in forum SubtitleReplies: 4Last Post: 30th Nov 2010, 21:24 -
Subtitles and ConvertXtoDVD 3
By sissyfoot in forum SubtitleReplies: 1Last Post: 10th Nov 2009, 22:14 -
Subtitles in ConvertxToDVD
By lanooz in forum Authoring (DVD)Replies: 0Last Post: 4th Nov 2008, 09:07 -
No subtitles with convertxtodvd !!
By hilario in forum SubtitleReplies: 2Last Post: 9th Jun 2007, 18:04
