Ive seen loads of GIF images that move like mini video clips and wondered how they were made?
does anyone know?
eg. http://img107.imageshack.us/img107/6608/zidane2pwn3sr3xl1sq2.gif
Hi,Originally Posted by vijaygunners
first there basically 2 kinds of gif... one is your standard still graphic picture.. and the other, what your referring to is called "animated gif's"
and just like your movie clips the animated clips are made of several frams that run fast... remember those old cartoon flip books?? smile... where youhave apicture on each page and you flips thru them and they appear to move... the same idea!!.....
People will create each frame and then they import those frames into a animated creator type program that will combine all the frames into one file and voila a animated gif...!!
my self I create very few.. but what i generally what i do is modify a animated gif to fit my needs..... and that where i use a creator program to do the edit...
now these creator programs some have a lot of abilities some very little, however you can convert let say a avi file into a animated gif!!... i have done that a few times..... but you have to cut out a lot of frames.. because the gif file becomes too large...lol...!!
if you want to take a closer look at how things done and such..... and maybe even makes some simple animated banners... quite easy, suggest download GIFCON from http://www.mindworkshop.com/alchemy/alchemy.html , it not the best but pretty good, userfriendly, and there help section is pretty good.... for a tutorial... it's shareware but what you donwload is the full version and there no limitation on features...!! unlike your demos and such......!!
final thoughts... it come in real hand if you make your own animated e-greeting cards, or put in your edited videos and such....... have a lot of fun with that
Gif Test
By budwzr in forum TestReplies: 13Last Post: 15th Feb 2012, 21:33 -
AVISYNTH for GIF
By ks47 in forum Newbie / General discussionsReplies: 4Last Post: 1st Sep 2009, 09:28 -
Converting FLI to GIF?
By impmon2 in forum Video ConversionReplies: 3Last Post: 18th Feb 2008, 02:18 -
animated gif
By snafubaby in forum Newbie / General discussionsReplies: 14Last Post: 27th Jan 2008, 13:41 -
.gif to mpg
By backdrop001 in forum Authoring (DVD)Replies: 3Last Post: 9th Jul 2007, 14:26
