hello
is there any way to mount a DVD of the AUDIO_TS + VIDEO_TS form? as we can do with ISOs in Daemon tools
thanks
You can try use the subst command, start->run and type
subst X: c:\folder
it wont be the same as a daemon tools mounted dvd though.
or make an iso from the video_ts folder with imgtool or dvd shrink. -
Is there a reason you need to mount it, or are you just trying to watch it?
Google is your Friend -
What's the difference between a DVD and a DVD disc with the AUDEO_TS and VIDEO_TS file structure on it? Is there something additional thats added when Shrink or some other app creates an ISO? Seems like if there is no difference, you could backup a DVD by using Windows Explorer to simply copy the files from one disc to another (assuming SL discs - I haven't used DL discs, so I'm guessing that could also throw a wrench in the works).
I'm not talking about backing up commercial discs of course. -
yeah you can do a non-commercial disk that way...
and .iso is an 'image' of a disk that most burning programs will recognise and burn. the VIDEO_TS is the actual file folder on the dvd, containing everything in its raw, file format. if you were to examine an .iso with a program like IsoBuster, you'd see the VIDEO_TS folder right there.I am just a worthless liar,
I am just an imbecil -
Think of it this way: DVD is just that: a DVD, with some info on it.
ISO is an "image". Think DVD info, but shrunk to a single file, kinda like a large newspaper shrunk to a microfiche/microfilm, but if you got a reader you can read it just the same. A disk image can be mounted as if its a disk, or burned to a disk.
DVD with VIDEO_TS folder is a valid VIDEO DVD (i.e. DVD containing common Video data) playable in any DVD Video Player. It follows the "standard" format.
Buying a monitor mount
By A Traveller in forum ComputerReplies: 6Last Post: 23rd Dec 2016, 00:26 -
Side Mount Intake Fan
By wulf109 in forum ComputerReplies: 3Last Post: 15th Nov 2011, 05:24 -
Can you mount an .ISO image to a hard drive , then copy the VIDEO_TS folder
By Bansaw in forum Newbie / General discussionsReplies: 8Last Post: 19th Jul 2011, 19:11 -
Mount a game disc or file
By slayer_of_all in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2010, 15:18 -
lcd wall mount help.
By nick101181 in forum Off topicReplies: 2Last Post: 13th Dec 2009, 09:20
