Hello,
I converted some Mov Files to VOB (DVD compliant) using Super.
How can I create a DVD with these DVD compliant VOB files?
(there are no IFO and VTS files).
Thanks in advance.
Results 1 to 9 of 9
I don't have the VOBs, so I can validate what you are doing, but these might help
https://www.videohelp.com/guides.php?guideid=16#16
And the second half of this one
http://members.dodo.com.au/~jimmalenko/test.htmRead my blog here.
They should still be VOBs, however there are other ways to skin a cat.
Start with VOBMerge to put them together into one big VOB. Then use VOB2MPG to demux them and author with something else. Do you have any authoring software ?
Before this, you could try opening one of the VOBs in the latest G-Spot (2.52beta) to see if it contains compliant video. Personally, I never understood the point of software that creates VOBs in isolation to a full DVD structure.Read my blog here.
Thank you guns1inger.
I've controlled a VOB file in Gspot.
Seems to be a correct file.
DVD "VOB" format
Mpeg-2 program stream << [1 vid, 1 aud]
sys bitrate: 10080 kb/s VBR
Audio: AC3
However IfoEdit gives the error:
Could not find any VOB unit in Vob file(s)
VOBMerge:
cannot download the software (need password)
DVD compliant and 60fps?
By fearmyrage in forum Authoring (DVD)Replies: 11Last Post: 28th Apr 2012, 22:51 -
DVD recorder conversion to compliant DVD
By snafubaby in forum Authoring (DVD)Replies: 4Last Post: 27th Dec 2009, 04:57 -
How do I make an MPEG-2 dvd compliant file into a authored dvd?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 12th Mar 2009, 15:10 -
Why is my movie not DVD compliant?
By johnharlin in forum Video ConversionReplies: 19Last Post: 3rd Jan 2008, 21:11 -
WMV to DVD compliant MPEG2 - TDA3 or DVD Maker - what is the right way?
By MagicSparky in forum Video ConversionReplies: 5Last Post: 23rd Aug 2007, 12:27
