    Jul 2006
    Chile
    When I transform an AVI file (1GB) to DVD (with Premier Pro or Producer Gold), the DVD file that results weigh 0.5 GB approximately, because it was compressed and it lose quality. How could I transform the AVI to DVD (VOBs) without compressing like that don't it lose quality the image (Example: AVI 1GB to DVD 1GB)? Thank you
  2. To keep quality loss to a minimum, you give it a higher bitrate, and you probably want it about 3 GB for the final size.
  3. give your dvd video the same bitrate as the avi have and the quality will be almost same and i am assuming that your avi is also in compressed format here.
    If you have a 1GB uncompressed avi then there is no way that you can make it of same size when encoding for DVD, as max audio/video bitrate for dvd is approx equal to 10 MB/s while uncompressed avi has lot more then that.
  4. If your AVI file is MPEG4 (divx, xvid, etc) you'll need at least 2 times as much bitrate for DVD MEPG2.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    or more.
    What you should have done was look at the length of the avi, put that into a bitrate calculator, then encoded to give it the correct bitrate for it's length. 2x for mpeg4 to mpeg2 is a minimum, and assumes the mpeg4 bitrate produced comparable quality to DVD. Most don't. This would require a bitrate around 2000kbps, whereas most mpeg4 encodes are done at around half that bitrate. To maintain the same quality you need closer to 3.x - 4x the size. It should never be smaller.
    Read my blog here.
  6. Member vhelp's Avatar
    Mar 2001
    New York
    Evening everyone
    [ sec A ]
    Source AVI Length vs. Compression sceme..
    Think about it.. when your source AVI origin is divX/XviD based, and depending
    on it's length, i.e., 2 hrs vs. 1 hrs, its a very good chance that it was highly
    compressed to fit a given outcome. I've seen many many forms of this compression
    format, but never seen anything aproach (assumed) original source, DVD.
    Since you don't seem to have any control over those avi's, its a good chance that
    you will have to feel (figure) out the best approach to *each* of those video avi
    files you have for processing >>-- AVI -> DVD. This usually intails a battery of
    trial n error test runs.
    [ sec B ]
    There are TWO types of video AVI's..
    Those that are compressed to divX/XviD are one format, and the other more common
    format via capture to AVI is the other format, i.e., DV; MJPEG; YUY2; etc.
    These are the avi's that will give you maximum outcome vs. the above, when divX/XviD.
    It's just that the sec A removes more of the video's detail than sec B. A lot of
    the video is manipulated to fool the eye to some degree. This is it's ultimate
    purpose, besides crunching for media space benefits.
    Now, if your source is from sec A, then you have some work ahead of you. I think
    that your's is such, and the aim of your (this) post is just that.. to achive the
    maximum out of your divX/Xvid video files. That is hard for anyone here to really
    answer. And since we don't have access to your avi's, all we can offer you is
    best guesses
    My suggestion..
    Start with a very high bitrate and work your way down, reducing the bitrate in
    each test trail run. The one that looks best to you, in terms of quality and
    media space constraints, is your goal.
    For example. If your media is DVD, then you already know it weights in at 4.3g
    per disc. That means, you have that much bitrate to dish out, assuming that
    your source is 1 hr in length. This example assumes a bitrate of roughly 9000
    and with a decent audio bitrate as well. I usually use 192k for audio.
    If your video each are 1 hr in length, then you have a basic starting point
    to work with.
    But, if you are trying to squeeze 2 hrs per disc, then you have even more work
    ahead of you. Mind you, this is all assuming that your video avi's are in very
    good quality. I doubt that. But, I will give you the benefit of my doubt
    -vhelp 4049
    Jul 2006
    Chile
    Thanks you very much. Very technical to me!!! I will study and test this and write you.
