Doing a little experimenting with current version of Simple DivX on a Win 98SE machine with plenty of RAM, HD space, speed (1.8ghz), etc.
My efforts crash every time with the following error:
MENCODER caused an invalid page fault in
module MENCODER.EXE at 016f:004dc3b5.
Registers:
EAX=62773130 CS=016f EIP=004dc3b5 EFLGS=00210216
EBX=01269ad0 SS=0177 ESP=0111fb40 EBP=00000240
ECX=00000000 DS=0177 ESI=01268e10 FS=3bd7
EDX=00591000 ES=0177 EDI=01269b70 GS=0000
Bytes at CS:EIP:
89 04 0a 8b 46 48 8b 6c 24 58 c1 e0 04 89 6c 08
Stack dump:
7f1c000c 00592000 00000240 00000240 012691a0 00000240 0111fb88 00437058 0234f00c 01217d90 01218694 00000000 0207a900 000fff60 00011800 01269ad0
[end of error message]
The AVI created is about 80-85% of the length of the original, will NOT play in WMP 9.0, but WILL play in VLC.
IF I could get Simple DivX to complete the recode, I'd have a very good quality file--IF.
Any suggestions?
What mencoder build is it using? Also can you post the command line?
Should also point out that despite the name if something uses mencoder, then that means XviD or libavcodec's own MPEG-4 encoder. If you want DivX, then you need to use something else, although I prefer XviD anyway. -
The mencoder build is dated 01/01/2006, possibly v4.0.2, from the DOS-window message that flashes by that I've been able to freeze if I'm fast enough to hit the "pause/break" key.
As to the command line, the details flash by very quickly when Simple DivX starts, but when I've been able to freeze it, the only apparent problem is "vcoder init failed ;( " and then the recoding continues as if everything is okay.
I do understand about Xvid vs. DivX, and prefer Xvid, too. It's just that the name of the program is "SimpleDivX" not "SimpleXvid" or I wouldn't have mentioned DivX at all.
Try one of my builds: http://ffdshow.faireal.net/mirror/mplayer/ that is assuming that you have a supported CPU.
I seem to be having the same problem, well, not exactly the same, but close.. apart from the fact that i am using Win XP SP2.
Anyways...
I downloaded the latest version of "simpleDivX 1.40.25" and it worked fine once, and only once.
Now everytime i try and convert another dvd, "mencoder" crashes, i managed to get a picture of what it says (because it flashes up and dissapears so quickly)
I can't work it out..
Any Ideas ?
I TRY, BUT DO NOT UNDERSTAND PROGRAM USUAGE OR COMAMND LINE BASIS
minizing artifacts with MEncoder for time lapse from JPGs
By jon_bondy in forum Video ConversionReplies: 0Last Post: 4th Mar 2011, 14:52 -
Video crashes all the time
By manicradio in forum Software PlayingReplies: 4Last Post: 9th Oct 2010, 22:38 -
I-Tunes crashes every time I try to play something :(
By Akhet in forum ComputerReplies: 4Last Post: 8th Dec 2009, 17:59 -
mencoder error AE_FAAC
By zackiv31 in forum LinuxReplies: 1Last Post: 28th Jan 2009, 20:54 -
Mencoder error while using GOTsent
By d2idan in forum Video ConversionReplies: 2Last Post: 6th Jun 2008, 12:04
