I have been using DVDMaestro to author my dvds and I just recently noticed that upon playback of a newly authored discs, the dvd will pause for a second at a self-made chapter point, then continue on. It resembles when a Dual Layer dvd changes layers. I really can remember if I changed anything in my authoring process. Is there a work around this? Is this just my dvd players (tried in 2 players)? Any help or info would be appreciated. I am using taiyo yuden discs.
Is it all chapter points, or only certain chapter points?
Did you add a VM command on the chapter(s) with the problem?
Regards,
George -
It was all chapter points. However, I believe I fixed the problem. It looks like I have been setting links to the end of my chapter points. Under the connections tab of DVDMaestro, I would link a chapter to the next. I thought I was assigning the "next button" on dvd remotes, but in reality I was just telling the dvd to skip/search to the next chapter, this caused the pauses. To assign "next" commands, you have to go under the advanced section.
When you set the links, I am guessing that using that option inserts a VM Command for that chapter point (which is why I asked if you were adding VM Commands to the problem chapters).
These VM Commands (cell commands) can cause the issue you described on some players (some players handle them better than others).
Regards,
George -
Just out of curiosity, are there real chapter points - i.e. chapter points in a single video title - or have you cut the video into chapter sized titles and linked them together ?
If it is the latter then you don't actually have chapters, you have multilpe titles in a titleset. Some players won't play these back seemlessly, regardless of how you link them.Read my blog here.
I have the entire movie on one line and I just inserted chapter points in 10 min increments. Upon playback on my standalone dvd player, when I hit next it goes to the next chapter just like I wanted.Originally Posted by guns1inger
Admittedly I have never used Maestro, but I have used many other authoring tools (DVD Lab Pro being my prefered) and have never had a similar problem. The Next button does extactly as you describe, but there is no pause when playing through a chapter point normally.
Read my blog here.
I have seen this happen when you add a VM Command to a chapter(s). Whether or not you see the "pause" between chapters will depend on the player -- player-x might play it smoothly, while player-y might pause briefly.Originally Posted by guns1inger
Here's a quote from the DLP Help files (page 193):
Technical Note: If chapter has a VM command a short pause may occur on that spot during playback.
Regards,
George
How do I set chapter points in an already authored DVD?
By midders in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2008, 18:57 -
Pixelation and Freeze-up on home-authored DVDs
By ctdvd in forum Authoring (DVD)Replies: 17Last Post: 22nd Sep 2008, 11:44 -
Help! - ntsc and secam versions of chapter authored pal dvds
By devdev in forum Video ConversionReplies: 3Last Post: 25th Aug 2008, 22:05 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 14:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 21:33
