I know what is and how to use batch converting from AVI to MPEG but how to use batch capturing from my DV camera to computer, when I have to replace an load next video cassete into camera. So what is the point of meanig of "Batch Capturing".
Regards.
QUALITY HAS A NAME
Never done it myself, but my understanding is that "batch capturing" enables the user to capture only certain parts from the source tape, thereby eliminating the need to edit unwanted footage later. The user tells the capture program which parts to capture and which not to. To do this you need both capture software that supports batch capturing and a playback device that can be controlled via the software (to play, fast forward to next clip, etc...). Typically there is a data port on the hardware device that connects the software to the hardware, such as with DV or through an RS-422 port on a pro machine. I'm sure there may be other port types.
need some batch file help
By iamspuzzum in forum ComputerReplies: 6Last Post: 22nd Mar 2010, 16:19 -
Batch file
By Anurag in forum ComputerReplies: 16Last Post: 19th May 2009, 11:27 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 00:00 -
Batch rendering
By TrupsT in forum Video ConversionReplies: 5Last Post: 5th Jan 2009, 00:21 -
Batch Screenshot Capturing from Video Input in realtime
By midimidi in forum Newbie / General discussionsReplies: 0Last Post: 14th Jul 2007, 09:10
