I have a movie in 23.976 fps, should I use 3:2 pulldown? Because I have subs for it, will they get out of sync if the movie will playback at 29.97 fps if I use "3:2 pulldown at playback"-option in my encoder?
I would rather not re-sync my subs which play fine with the movie in 23.976.
But as I want to make a DVD of it, what should I do? Is the pulldown even necessary to play the mobie in my standalone DVD-player?
Thankful for help!
Hi-
If making an NTSC DVD from it, yes.
No.
Yes, plus you can't author for DVD anyway without having a compliant video, which means 29.97fps for NTSC. -
Thank you for your advice.
Well, if someine else would like to fill me in then I would be very thankful -
Set Encode Mode to "3:2 pulldown when playback."
Set Frame Rate to "23.976 fps (internally 29.97 fps)".
Standard definition NTSC TV supports only one format: 59.94 fields per second. If your file is 29.97 frames per second it is sent as two fields (2 * 29.97 = 59.94). If your video is
23.976 frames per second the DVD player alternates between sending each frame for 2 fields and 3 fields, an average of 2.5 fields (23.976 * 2.5 = 59.94). In both cases the overall running time is not changed.
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 16:53 -
playback with no pulldown on a dynex 60hz lcdtv
By octeuron in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2010, 10:05 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 06:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 03:25 -
Film Pulldown
By Soapm in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 18th Jun 2007, 12:20
